VSA is broken?
Old Nov 22, 2015 | 12:32 AM
Anjyla's Avatar
3rd Gear
My car was in the shop for over a month (here in Germany). They did my front brakes and my parking brake. When I picked up my car the VSA "off" was lit up on my panel. The shop claimed ignorance to it. I took my car to inspection here and the guy said my tie rod was loose. So I thought that may have to do with the VSA not working; however, fixing the tie rods didn't have any effect on the VSA.
I'm guessing that when they did my parking brake they messed up my VSA. Any ideas, similar situations, advice or suggestions? Thank you.
Old Nov 22, 2015 | 01:20 AM
01acls's Avatar
Old Nov 23, 2015 | 02:58 PM
pohljm's Avatar
Wheel sensors prolly not plugged back in
Old Nov 27, 2015 | 03:30 AM
Anjyla's Avatar
3rd Gear
@ 01acls .... I know about the VSA button. The button was the first thing I pressed when I got my car out of the shop and saw the VSA warning light was on. I even reset my whole car (battery) to see if that would make a difference but it didn't.
Thanks, pohljm, I'm going to see if I can get someone to check that out and see if that will fix it. Hoping for the best!
Old Nov 28, 2015 | 10:43 AM
Darkwave's Avatar
Hi there, I was just wondering if you found out what the problem was. I have a 2005 Acura TL, the VSA light comes at random times and the rpm, speedometer and temperature gauge drops to 0 intermittently(while driving ). I'm looking for any help that I can get.
Old Dec 1, 2015 | 08:38 AM
Anjyla's Avatar
3rd Gear
Darkwave, I haven't made it to my mechanic yet. Have u made a post about your problem? I haven't had any of that happen. �� I hope someone can help.
Old Dec 1, 2015 | 09:11 AM
Darkwave's Avatar
I haven't made posted the issue with my car as yet. That's my next course of action. Thanks for your reply.
Old Dec 1, 2015 | 08:11 PM
F(x)'s Avatar
Do you know if the shop cleared ABS codes? I recently cleared all ABS stored codes and this caused a VSA neutral position relearn to be required. Until I did the relearn, the VSA light was on all the time.
Followed the steps in the first post below (but the key is to clear ABS codes then do the relearn in the same cycle, ABS code was 84-01 Sensor Logic Failure.
Error Code 84 - VSA sensor neutral position memorization - Acura TSX Forum
Old Dec 1, 2015 | 10:03 PM
Darkwave's Avatar
Omg...that's the same code that I have. I'm gonna try this procedure tomorrow. Thank you very much. I will post the results.
Old Dec 5, 2015 | 03:32 PM
Darkwave's Avatar
Hey guys, so the good news is the VSA light is not on all the time anymore. However, very intermittently the the rpm, speedometer and temperature gauge drops to 0 and the VSA light comes on until the key/ignition is cycled.
normaspirated
Dec 27, 2015 02:46 PM
chasingthecool
Dec 5, 2015 10:57 AM
dap0901
Nov 26, 2015 10:23 AM
lians60
Nov 16, 2015 07:45 PM
RLX-Sport Hybrid
3G RLX (2013+)
17
Nov 16, 2015 02:02 PM
