VSA and brake light on
Old Jan 1, 2011 | 02:57 AM
gotkilled's Avatar
NBP is a pain...
This morning my VSA and brake light went on. When I press the VSA off button, it doesn't do anything and the brake light will turn off once I step on the brakes but it comes back on once I step on the gas.
It has been fairly cold in Socal so I'm not sure if that could have affected the VSA system. I've tried turning off the engine and restarting it and the VSA light/exclamation mark and brake light will go on in about a minute.
When I first drove the car this morning, it was on for about 10 minutes then the lights turn off but came back on the next time I started up the car. Now, each time I start up the car, the VSA/brake light goes on.
What should I check for? From what i've found it could be anything from a faulty yaw/abs sensor, brakes or the app sensor. There is no check engine light on btw.
Old Jan 1, 2011 | 09:59 AM
csmeance's Avatar
Check your tail lights and see if they are working! If not, it's probably a bad brake switch.
Old Jan 1, 2011 | 12:26 PM
01tl4tl's Avatar
ck the master cyl cap- remove it and ck fluid level sensor is freely sliding
and electrical connections are clean
the deafult is ON for vsa at startup--you manually override it for certain situations-
then the dash light should stay on to remind you the system is OFF--thats why the light is yellow
I could be wrong- Im gen2 so dont yell at me for trying~
Old Jan 1, 2011 | 11:13 PM
gotkilled's Avatar
NBP is a pain...
Checked the third brake light and it's working fine.
Checked the master cylinder cap and it looks like it's good. Brake level fluid is good.
It's really weird, when I step on the brake, the brake light goes off. When I let go of the brake, the brake light goes on.
Old Jan 7, 2011 | 06:39 PM
EATSLEEPRACE's Avatar
6SPEED FEVER
I HAD SAME ISSUE......ITS THAT YOUR LOW ON BRAKE FLUID.....
Old Jul 3, 2012 | 06:24 PM
JoeyDiamonds's Avatar
Did you ever figure out the issue?...mine just came on today...but it has been 2 solid weeks of 95+ degree weather
Old May 23, 2014 | 09:30 AM
Future23's Avatar
Hey I just encountered this problem, has anyone figured out what da solution to this problem is? My break light and VSA light comes on n stays on but my break pads are fine n fluid is good from what my mechanic said.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
Allen_442
Sep 8, 2015 06:01 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
