Vsa
What condition existed when they came on??
and the last thing that happend just before then?
Here is the owner book link- may find your answer there
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
Conditions were normal....dry roads & sunny! It had rained the a few days ago in the Dallas area. I had just washed my car & I noticed the warnings on the way to the store....weird huh?
I'll check out your link....thanks!
Same issue.
Same thing happen to me. It's fixed now. I had an independent shop fixed my speed sensor that cost over $200. It only got rid of the ABS indicator, not the VSA. So I had to go to the dealer for that. Here is my post on it.
https://acurazine.com/forums/showthread.php?t=171200
Well, I took the car to the dealer today so I should find out tomorrow what the problem is....I'm sure it won't cheap! UGH!! I'm sure it will get fixed....hopefully, it won't be too costly.
its often a trans warning signal, but can also mean a broken speed sensor at a wheel - or water got in and shorted it out , or the car was lowered or brake job and wire-sensor was damaged
Just like codes- they are only clues of things to check
Vsa & Abs
Well, here's the fix when the VSA & ABS indicator lights come on my TL.
I took my TL to the dealer, & after their diagnostic test. They determined it was a speed sensor. So they replaced the speed sensor located in the driver's side rear wheel. Replacing the sensor fixed the problem & the indicator lights (VSA & ABS) did not come on!
It was raining a few days before the problem occurred so the sensor must have shorted out. That's the only thing that I can think that caused the problem.
The cost for the repairs was $225.00. The part only cost $26.80.
Jamus22
06-11-2023 10:08 AM
mada51589
05-03-2022 08:54 PM
