Vsa
Old Jan 27, 2008 | 03:16 PM
my_2004_TL's Avatar
Go Cowboys!!!
Vsa
Why or what would make the following warnings turn on my 2004 TL....VSA Activation Indicator & ABS Indicator.
Old Jan 27, 2008 | 03:57 PM
01tl4tl's Avatar
What condition existed when they came on??
and the last thing that happend just before then?
Here is the owner book link- may find your answer there
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
Old Jan 27, 2008 | 05:02 PM
csmeance's Avatar
one of the wheel sensors may be faulty, go to the dealer and have it checked out.
Old Jan 28, 2008 | 08:48 AM
my_2004_TL's Avatar
Go Cowboys!!!
Conditions were normal....dry roads & sunny! It had rained the a few days ago in the Dallas area. I had just washed my car & I noticed the warnings on the way to the store....weird huh?
I'll check out your link....thanks!
Old Jan 28, 2008 | 08:49 AM
my_2004_TL's Avatar
Go Cowboys!!!
How much do you think it will cost if it's a sensor?
Old Jan 28, 2008 | 09:29 AM
t0talacuratl's Avatar
Green Machine
Same issue.
Same thing happen to me. It's fixed now. I had an independent shop fixed my speed sensor that cost over $200. It only got rid of the ABS indicator, not the VSA. So I had to go to the dealer for that. Here is my post on it.
https://acurazine.com/forums/showthread.php?t=171200
Old Jan 29, 2008 | 01:02 AM
my_2004_TL's Avatar
Go Cowboys!!!
Well, I took the car to the dealer today so I should find out tomorrow what the problem is....I'm sure it won't cheap! UGH!! I'm sure it will get fixed....hopefully, it won't be too costly.
Old Feb 1, 2008 | 03:59 PM
banelba's Avatar
I think it has to do with the transmission
Old Feb 1, 2008 | 06:58 PM
01tl4tl's Avatar
its often a trans warning signal, but can also mean a broken speed sensor at a wheel - or water got in and shorted it out , or the car was lowered or brake job and wire-sensor was damaged
Just like codes- they are only clues of things to check
Old Feb 2, 2008 | 03:33 PM
Green Machine
Yeah I thought the same thing, because my tranny and clutch was acting weird before I got the sensor fixed. Now they are working fine.
Old Feb 3, 2008 | 12:48 PM
my_2004_TL's Avatar
Go Cowboys!!!
Vsa & Abs
Well, here's the fix when the VSA & ABS indicator lights come on my TL.
I took my TL to the dealer, & after their diagnostic test. They determined it was a speed sensor. So they replaced the speed sensor located in the driver's side rear wheel. Replacing the sensor fixed the problem & the indicator lights (VSA & ABS) did not come on!
It was raining a few days before the problem occurred so the sensor must have shorted out. That's the only thing that I can think that caused the problem.
The cost for the repairs was $225.00. The part only cost $26.80.
Old Feb 3, 2008 | 10:59 PM
banelba's Avatar
Ed Voydes Acura quote me $60 list for the sensor minus my 20% discount. Anyone has the part number.
mada51589
Jan 9, 2025 04:40 PM
Jamus22
Jun 11, 2023 10:08 AM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
polish_pat
Sep 30, 2015 12:22 PM
