Vibration when gas is applied
Old Dec 23, 2011 | 09:26 AM
TL6SPD's Avatar
Veeeee Tec
Hey guys,
I own a 2004 TL 6-Speed. Car currently has 142k on it. All maintence is up to date.
-Rims are straight.
-New tires.
-Balancing and Alightment completed.
To make a long story short: Couple months back, the car started shaking violently when gas is applied at 60 mph+, but when you let go of the gas and just cruise( there is no vibration/shaking). My buddy who is a mechanic.. looked thru the car and noticed a Tie rod end that was loose, so i bought a new one and the vibration is still occuring. Its driving me nuts and i need to get it fixed.
His next idea is Axles... what do you guys think?
Thanks in advance!
Old Dec 23, 2011 | 09:43 AM
Acura_Dude's Avatar
David_Dude
Sounds like axles to me. Do you know if they've ever been replaced? They wear out too.
Old Dec 23, 2011 | 09:57 AM
TL6SPD's Avatar
Veeeee Tec
I bought the car with 57k. I am no sure if they were ever replaced. I doubt it. if i replace them, i will do both already... just i am wondering what else it could be. Itll suck if i replace them and vibration will still be present.
Old Dec 23, 2011 | 02:15 PM
Royik1157's Avatar
The problem is that the joints in the axles are worn out. same thing is happening to mine now. theyll start to leak grease soon so get it fixed before you hear the clicking sound
Old Dec 23, 2011 | 02:21 PM
mY sLOW UA6's Avatar
In my TL when I hit the gas at low r's such as around 1300rpms i get a vibration too, could this be my axles. It never did this before.
Old Dec 23, 2011 | 08:25 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
axles been there, done that...mine went bad at 42k mi though. replaced at 50k. all is well again. vibration on low speed acceleration. inner CVs...clicking with turns....outer CVs.
Old Jan 2, 2012 | 02:40 PM
TL6SPD's Avatar
Veeeee Tec
Anymore suggestions? I just dont want to replace the axles and still have the same issue present.
Thanks guys!
Old Jan 2, 2012 | 03:21 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
motor mounts?
Old Jan 2, 2012 | 05:15 PM
ABP_04TL's Avatar
6-SPEED LOVER
Half shaft bearing? But i think axles aswell
Old Mar 2, 2012 | 12:48 PM
mc_holla's Avatar
Thanks guys!
Any updates on your issue?
Going in to day to have my Driver-side axle replaced (passenger-side done two weeks ago) and am praying that will fix this shimmy. Cant take it anymore! Lol
Old May 1, 2012 | 08:31 AM
TL6SPD's Avatar
Veeeee Tec
Axles fixed the issue.
Car drives new.
Old May 1, 2012 | 09:25 AM
gideon's_test's Avatar
Did they replace the intermediate shaft bearing?
Old May 1, 2012 | 02:50 PM
mc_holla's Avatar
Car drives new.
Glad to hear that. Did you go with OEM or Aftermarket axles?
Old May 1, 2012 | 07:18 PM
professor48's Avatar
Some TLs have a vibration caused by the motor mounts. A new, improved style motor mount is available and should be used when the mounts are replaced. Check your mounts for tears. My 08 still has some vibration at 1300-2000 rpm even after the motor mount change. It's due to go to the dealer on Thursday for an oil change. I'll have them check the inner CVs while it's there. Hy
Old May 2, 2012 | 08:55 AM
TL6SPD's Avatar
Veeeee Tec
I bought OEM axles from Acura. I wouldn't go AM...
My buddy that works at Lexus did the repair for me.... I am not sure about the bearing.. i just bought (2) brand new OEM driveshafts... The passenger side had a lot of play, so that was the cause of the severe vibration.
Old Sep 14, 2012 | 01:03 PM
mc_holla's Avatar
FYI:
Replacing my driver-side axle fixed my driveline vibration issue. Think my car drives smoother now than it ever has!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
San Yasin
Sep 29, 2015 10:52 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
