Vibration in Front End Periodically
Old Apr 18, 2013 | 12:07 PM
sleeper22's Avatar
Awhile back I was experiencing a thumping and vibration in the front end. It was found to be a sticking caliper. Got both calipers replaced about 6-months ago and all has been well until recently. Again I'm experiencing a vibration but it seems to a little different. It comes and goes now and starts around 55-60 mph and lasts for about a minute and then goes away. I am not hearing any roaring noise like a bearing. The vibration is very noticeable but like I said it eventually goes away. Anyone experience this before?
Old Apr 18, 2013 | 12:18 PM
JDMKNIGHT's Avatar
Hey buddy it's probably most likely your front and side engine mounts are done that why you get that vibration when going 50-60 mph. Take it to a shop and ask them to check it out your engine mount I'm sure that what it is .
Old Apr 18, 2013 | 12:21 PM
sleeper22's Avatar
I had these replaced under extended warranty awhile back. How many mounts are there?
Old Apr 18, 2013 | 12:34 PM
JDMKNIGHT's Avatar
There is four of them one in the front of the engine, one on each side and one behind the engine.
Old Apr 18, 2013 | 02:27 PM
sleeper22's Avatar
OK thanks I will call Acura and ask how many they replaced. I am confused why this would cause vibration at said speeds and then it smooths out.
Old Apr 21, 2013 | 11:03 AM
anx1300c's Avatar
There are three, not four. A front, rear, and passenger side. The transmission is on the driver's side, where there is no engine mount.
Old Apr 22, 2013 | 06:22 AM
sleeper22's Avatar
I'm still confused why this wold cause a temporary vibration? Two of the mounts were replaced and I think the rear one wasn't if there are three.
Old Apr 24, 2013 | 08:06 PM
flyromeo3's Avatar
hmmm.....I would rotate my tires and see if the problem follows or goes away.
Old Apr 24, 2013 | 08:18 PM
sleeper22's Avatar
I had my mechanic look at the car today. He drove and checked all suspension components and inspected tires and wheels. He said when he spun up the tires on his machine two tires had a little hop to them but nothing major. Wheels are not bent so I am taking it back to the tire store and having them re-balance and and check the tires and rotate.
TLDude876
Dec 28, 2016 03:18 PM
02tljj
Sep 11, 2015 12:37 PM
08 NBP TL
Sep 8, 2015 08:49 PM
