variable steering
Old Jun 22, 2017 | 09:55 AM
jwade04's Avatar
3rd Gear
variable steering
2004 Acura TL, steering is loose @ some points and tight @ some points. Started steering feels like it overturns and the car finally catches up to the steering. Now the power steering is intermittent and the steering wheel is completely upside down at strait ahead. Coming into a long curve at a higher speed the steering wheel will come back more than what its actually turned. so confused as to what the issue is??? is it a sensor, is it the VSA, is there a gear box? Any help is appreciated!
Old Jun 22, 2017 | 10:23 AM
used car? when did it start displaying this behavior? is there PS fluid in the reservoir?
Old Jun 22, 2017 | 10:35 AM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
First thing I would do is check the PS fluid level. Could be PS pump failing.
Old Jun 22, 2017 | 10:36 AM
jwade04's Avatar
3rd Gear
195K car still has fluid in the reservoir, pump still has pressure, and vsa light on the dash had been stored...
Old Jun 22, 2017 | 10:43 AM
jwade04's Avatar
3rd Gear
Its had some light popping in the steering since i got it in Jan but just recently started these direct steering issues. Some seem to believe that there is teeth broken on the rack causing the oversteer issue and popping noise but while researching this issue ive came across the fact of it having rotary valves in the rack and vsa steering sensor.
gavriil
Jan 14, 2026 12:47 PM
00TL-P3.2
Jan 15, 2022 11:42 AM
1StGenCL
Wash & Wax
Oct 16, 2016 04:41 PM
Nashua_Night_Hawk
Dec 7, 2001 10:58 AM
BarryH
Jul 1, 2001 05:56 AM
