Urgent locked out of my car. please help!!
so my battery plug under my hood came undone, so now i cant use my keyless entry, i tried using my key to unlock the door but its not working. what can i do? please help asap i need to get in my car! thanks~ alot azine
thats what i was thinking, so why cant i unlock my door with my key? maybe whoever took the door apart didnt put it back on right? so what shall i do? dont wanna call pop-a-lock and pay like 50 buck
How do you know that?
Who took the door apart?
You can try a little force on the key, but be careful.
If nothing changes, time to call a locksmith...
Also what do you mean by the key is opening the lock? Is the key turning at all? Is it moving freely?
You can try prying the door at the top very gently with some sort of wedge just enough to insert a long string but hold both ends and try to get it around the vertical lock button and pull back and up at the same time.
yes, the key and lock are mechanical. it does not rely on the battery.
my car is on jack stands with the battery disconnected right now.
I just tried it. I locked the door from the inside..and unlocked it successfully with the key
Ok the same just happened to me.
Trying to open with my keys is not working. It turns but nothing happens! Keyless worked on my trunk and I had to crawl through. Totally bogus and embarrassing. Quite bizarre because i can normally open by putting in the key for instance when using the valet key! And the keyless entry is not working. Has anyone else over the past nine years come across this and figured out what we do?
rockyboy
08-04-2024 10:35 AM
