UR Crank Bolt Wobble
Old Jun 25, 2009 | 04:01 PM
NedShneebly's Avatar
practicing nihilist
Can someone peek through the inspection port for the crank while their car is running and see if their crank bolt oscillates in the same fashion, please. The pulley system itself doesn't look to be unbalanced. This has me worried but it's going to the dealer for warranty work soon and I'll through a couple bucks their way to torque it down.
Old Jun 25, 2009 | 04:05 PM
InFaMouSLink's Avatar
Chapter Leader (NY/NJ)
SOMEbody will chime in on this before me probably but if not i'll do it tomorrow when i get back to NYC.
Old Jun 25, 2009 | 04:17 PM
practicing nihilist
thanks, Bro.
Old Jun 25, 2009 | 11:10 PM
pohljm's Avatar
Looks like the end of the bolt may have been bent a little when you broke it loose
Old Jun 26, 2009 | 07:20 AM
practicing nihilist
That's what I suspected. Its holding fine but just scared the crap out of me when I 1st noticed
Old Jun 26, 2009 | 04:33 PM
I hate cars's Avatar
Replace it now. You have no idea how much trouble that can cause later on.
Old Jun 26, 2009 | 07:31 PM
gonna go now and record it for you ned.
Old Jun 26, 2009 | 08:33 PM
sorry for the bad lighting.
http://s479.photobucket.com/albums/r...t=MVI_6090.flv
Old Jun 27, 2009 | 07:23 AM
practicing nihilist
sheet, yours is nice and balanced. Belt track is fine and nothing's squeaking.
I have aligators closer to the boat right now - pre-cat or j-pipe busted a weld last night...sounds like a 1984 datsun with a muffler rusted out near the front axle.
Old Jun 27, 2009 | 08:11 PM
when they took mine off it was with a flamethrower. nothing squeaking except tensioner when AC is on. OMG I WANNA FN KILL MYSELF. gonna get it replaced this week. sorry about the weld. hope this helps bro.
Old Dec 9, 2015 | 04:15 PM
paperboy42190's Avatar
I just noticed earlier that my crank pulley looks a bit off balanced. Its definitely on centered, and the crank pulley bolt is torqued down. The middle circle part looks balanced as it spins, but the outer diameter of the pulley looks like it has a ~1mm of wobble. Also, the bolt washer looks like it has a bit of a wobble too. Car drives perfectly fine though
Old Dec 9, 2015 | 04:49 PM
Turbonut's Avatar
Probably nothing, but in extreme cases the rubber in the balancer can wear, become hard, cause a wobble and then the outer part will separate.
Old Dec 9, 2015 | 05:05 PM
nfnsquared's Avatar
^^^ Yup. Perfect time to pick up a stock size light weight pulley, ~$130 shipped
Old Dec 9, 2015 | 05:41 PM
Which ones are ~130 shipped? The UR crank pulley looks to be ~200?
Old Dec 9, 2015 | 06:36 PM
thisaznboi88's Avatar
ralco UR knock off
Old Dec 9, 2015 | 06:52 PM
nfnsquared's Avatar
^^^^ this
Meh, they've gone up a little bit: $143 shipped on Amazon.
http://www.amazon.com/Ralco-RZ-914931-Underdrive-Pulleys/dp/B001VQJ9MM http://www.amazon.com/Ralco-RZ-914931-Underdrive-Pulleys/dp/B001VQJ9MM
There is a seller on ebay for $140 shipped or best offer, but they never answer the phone and they have some bad reviews:
http://www.ebay.com/itm/Ralco-RZ-Cra...B_I1UA&vxp=mtr
acuratl26
Apr 23, 2020 07:30 PM
tsx_boy
Dec 13, 2019 08:33 PM
neuronbob
23
Jul 16, 2019 10:48 AM
Charles Bennett
Jan 28, 2018 08:53 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
