trunk sensor?? where is it?
Old Sep 9, 2009 | 04:49 PM
tltoledo's Avatar
does anyone know where the trunk sensor is?
my multi function display doesnt show me when my trunk is open. i think it may be a bad sensor, anyone know where i can find it?
Old Sep 9, 2009 | 05:44 PM
djtanveer's Avatar
hah thats inside the locking mechanism and its a bitch to get into because its so small..... but good news is that the new lock only runs about $60ish from the dealer.hope this helps
Old Sep 12, 2009 | 12:27 PM
$erega's Avatar
http://www.oemacuraparts.com/partloc...layCatalogid=0
Item 4. But perhaps you have a problem with the wiring
Old Sep 12, 2009 | 06:39 PM
acuratech239's Avatar
Acura Cert MASTER TECH
I suggest checking to see if the light in the trunk comes on when it's open. It's another way to narrow down what you'll have to diag to figure out the problem. Replacement isn't too hard, just remove the lower half the inner trunk lining (some plastic clips/screws, depending on year, one screw, and the two rubber things), and then it's just two bolts, the connector, and the manual trunk cable release. The two bolts are 10mm. If you've never done one, I say it's a 20 minute repair. If you've done them before, lower that to 10 mins or less! This is assuming you're doing the latch assembly. Good luck!
baelim
May 10, 2018 09:53 AM
RobbDizzle
Oct 15, 2015 11:16 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
justin.w13.walker
Sep 22, 2015 02:21 PM
