Trunk light wires - which one is positive and negative?
Old Feb 3, 2012 | 08:46 PM
guitarplayer16's Avatar
Today I was in the midst of installing my trunk light cold cathodes, and making a DIY for it.
I spliced the red wire of the cold cathode into the thicker yellow and blue wire (positive?) and I spliced the black wire from the inverter to the grey/blue wire (negative?)
I assumed this was right as I just assumed the thicker wire was positive.
Well, plug the battery back in, and open up my trunk to test out the light - they didn't turn on.
Then a second after opening my trunk, I hear this mini explosion like "poufff" sounding like it came from the inverter, and I see a little bit of smoke (don't know where it's from, the inverter or trunk light wires). It smelled bad too.
I figured I would test out the inverter plugged directly to the batteries and alas - nothing turned on.
Fried my inverter?
What was the cause though??? I'm pretty sure I spliced everything right!
The only thing I could think of that fried my inverter was that I had the polarities mixed up...
Old Feb 4, 2012 | 07:31 PM
paperboy42190's Avatar
once my car comes back from the body shop(next friday) i can tell you for sure.
Old Feb 4, 2012 | 07:33 PM
primus's Avatar
good job lol
Old Feb 4, 2012 | 08:34 PM
Thanks buddy!
By then, I'll have my new inverters ordered since I blew my one inverter.
For now, my cold cathode tubes are mounted and just chilling there waiting to be powered up! hahah
Old Feb 5, 2012 | 10:08 AM
Jesstzn's Avatar
Just grab a cheap multimeter from Radio Shack etc and test the wires .. will tell you which is +. And they are always handy ...
Old Feb 5, 2012 | 06:16 PM
I do have a multi-meter and tested it already.
My wiring was CORRECT, but somehow my inverter blew up?
The red lead to the blue/yellow wire and the black lead to the gray/blue wire read positive.
THe other way around read negative.
This means the blue/yellow wire is the positive doesn't it?
I hooked the red on the inverter wire to the blue/yellow wire and it fried my inverter.
Could just be a bad inverter, but I'm ordering more.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
Ny1718
Sep 11, 2015 09:21 AM
Phambam12
Sep 6, 2015 06:57 PM
