trunk light trouble
Old Jun 1, 2009 | 11:05 PM
saltysteve's Avatar
trunk light trouble
i bought a tl and the trunk light never worked - i thought it was just the bulb so i replaced it and nothing
what now?? how do i fix this??
Old Jun 1, 2009 | 11:48 PM
JwongTLS's Avatar
check fuse?
Old Jun 2, 2009 | 12:16 AM
saltysteve's Avatar
how many fuse boxes are there?
i checked the fuses
Old Jun 2, 2009 | 12:39 AM
Elegant TYPE S's Avatar
Being an Acha Bacha in
pull the trunk liner down by removing clips and check the wiring.
Old Jun 2, 2009 | 12:44 AM
saltysteve's Avatar
aw shiz... k - i guess ill be getting out a volt meter
Old Jun 2, 2009 | 06:25 AM
LoveMyTL-S's Avatar
You have fuses on your drivers side kick panel and also under the hood. But I'd check at the kick panel first. Volt meter is your friend. Good luck.
Old Jun 2, 2009 | 07:43 AM
Trew's Avatar
All you need is a test light. You don't have to undo the carpet. Just pop out the lens and stick a test light probe into each connector (2). You can clip the ground cable on the trunk latch pin right where your balls are.
Old Jun 2, 2009 | 08:34 AM
saltysteve's Avatar
k cool ill try that today but im not grounding anything to my balls!
saltysteve's Avatar
i hate this tooth ad- it freaks me out!
mada51589
Jan 9, 2025 04:40 PM
handsom-hustla
Nov 13, 2015 05:04 PM
PortlandRL
Sep 14, 2015 12:01 PM
EE4Life
Sep 11, 2015 10:13 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
