Trunk barely opens now
Old 10-02-2007 | 08:00 PM
0550TL's Avatar
6th Gear
I just installed a spoiler on my Tl and when I go to pop the trunk it really doesn't open at all. What do I need to do to get this fixed? I heard something about new trunk springs or something like that. Thanks in advance
Old 10-02-2007 | 08:41 PM
harddrivin1le's Avatar
Most cars have a second position for the spring ends (they are torsion springs) that can add a little extra pop. Try that first.
If that doesn't work then visit your dealer and see if the list stiffer torsion bars for cars equipped with deck lid spoilers.
I would have avoided the spoiler altogether and instead spent the money on something that would actually improve vehicle performance.
Old 10-02-2007 | 08:44 PM
0550TL's Avatar
6th Gear
If I ask for your advice on what I should do to my car I'll let you know bud........
Old 10-02-2007 | 08:47 PM
This thread lists different springs for this purpose:
https://acurazine.com/forums/showthread.php?t=163045
Old 10-02-2007 | 09:00 PM
You want these springs. (These are Acura part numbers.)
08F12-SEP-20020
08F12-SEP-20021
Call your Acura, dealer order ONE of each (left and right side) and you're all set, "bud."
Old 10-02-2007 | 09:02 PM
jupitersolo's Avatar
nnInn
With those springs, there is a special tool as well, it's been over a year for mine. But I didin't mess with it.
Old 10-02-2007 | 09:04 PM
I have to think that one could make do with vise grips (with the jaws wrapped in protective tape) to remove and install the springs, but maybe I'm wrong.
It might be worth paying the dealer to install them if a special tool truly is required.
Old 10-02-2007 | 09:10 PM
Bearcat94's Avatar
AZ Community Team
08F12-SEP-20020
08F12-SEP-20021
If I read the referenced thread correctly, these ( ^^ ) are the Wing Spoiler springs - even more heavy duty than the Type-S Trunk Springs.
The Type-S Deck Lid Spoiler springs are these (and a good bit less expensive too):
Originally Posted by datmrman
For all that have installed a Type-S spoiler on their cars, have you considered replacing your trunk springs with the stiffer Type-S trunk springs? Has anyone tried?
From acuraoemparts.com:
Part #10 74871-SEP-A20 SPRING, R. TRUNK OPENER 1 2007 TL 5.77
Part #11 74872-SEP-A20 SPRING, L. TRUNK OPENER 1 2007 TL 5.77
Theoretically, these springs should allow the trunk lid to open up higher than the base TL springs (since the Type-S spoiler is bigger, heavier ). For about $12, if it works, I'm going to do it. I have a feeling I will probably need a special spring installation tool to do the swap.
There have been previous threads on the wing spoiler springs, but they're more expensive than these and I'm not sure if I can buy them separate from the spoiler. Thoughts/comments appreciated.
P.S. Kennedy, I saw your thread in the Black Market.
Here is the thread on the Type-S spoiler installation: I have installed a type-S spoiler on my 05 TL
Old 10-02-2007 | 10:11 PM
He said he installed "a spoiler" on this car and gave no other details, other than the fact that the trunk "doesn't open at all well."
He should get the heavy duty springs unless he installed a relatively small lip spoiler (like the one that comes on the type S).
Any type of wing mandates the heavier springs.
Either way, he has the information he needed and can choose from either choice. Looks like be bailed out of the thread right after he read my post and without bothering to say "thanks."
Oh, well...
Old 10-02-2007 | 11:57 PM
0550TL's Avatar
6th Gear
I haven't had time to write back yet. As you can see ^^ I wrote Thanks right after you gave me some info and a TIA after I first posted.
I'm just not in the mood for your .02 cents on what I should do to my car, I really don't need performance parts for my DD.
Here's the story I installed a OEM lip spoiler and I have noticed a pretty big difference in the way the trunk pops now.
So just call my local Acura dealer (Or is there one you could recommend) tell them those parts numbers and I"m good to go? If so Thanks harddriven for your help
Old 10-03-2007 | 12:49 AM
Bearcat94's Avatar
AZ Community Team
My
If you're going for the Type-S Trunk Lid Springs, they're cheap enough at list price (about $15 for the set), just get 'em local.
Here's the website with that parts diagram and parts list.
http://www.acuraautomotiveparts.org/...s=&view=normal
mlody
12-04-2019 03:11 PM
07-16-2017 08:33 AM
soupi
14
11-15-2015 12:15 PM
hashbrown
09-29-2015 01:13 PM
