transmission switches...more than 3rd & 4th?
Old Aug 20, 2014 | 01:36 PM
blownby's Avatar
So after some reading it seems worthwhile to replace tranny switches...
I have 05 tl with 110k. Are there just the 2 switches or more?
Anyone have part numbers offhand. The more i search the more confused I get as to which are the correct numbers.
here is what I have:
The correct P/N for the 3G TL should be:
04-06 TL (Texas Instruments, TI)
28610-RAY-003 3rd
28600-RAY-003 4th
Also anyone know if my wife's 04 accord has same tranny and would use same switches. Her car is a 4 cy tho. her car has bad shudder in 4th gear, seems like it doesn't know if it want to go to lock up? Maybe a swap could help?
Thanks,
Old Aug 20, 2014 | 01:49 PM
MandoTL's Avatar
Also anyone know if my wife's 04 accord has same tranny and would use same switches. Her car has bad shudder in 4th gear, seems like it doesn't know if it want to go to lock up? Maybe a swap could help?
Thanks,
Here is the DIY thread for the switches.
https://acurazine.com/forums/3g-tl-2004-2008-93/110-diy-guide-replacing-3rd-4th-gear-pressure-switch-3g-tl-2004-2006-a-729149/
Part numbers for 3rd and 4th are also in the thread:
28610-RAY-003
28600-RAY-003
They are colored so I can't remember which pressure goes with which color but once you access the replacement area(if DIY) then I dont think it will be that hard.
As for the 04 accords tranny I can't say if they are the same in tranny design. I'll let a veteran chime in to answer that one.
Jul 16, 2017 07:33 AM
joflewbyu2
Oct 8, 2015 11:16 AM
flyromeo3
Sep 24, 2015 11:24 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
