Transmission Shutters!!!
Old Sep 3, 2010 | 03:14 PM
johnc04's Avatar
...04 Tl auto. Not a crazy shutter but it happens. Seems like it doesn't change gears as smoothly as it should. 73,000 miles on it. I just bought it in June. Took it to the dealer and they re-produced the shutter and said I had too aggressive of a tire on the car. I am going to take it in again and document each time I tryed to get it looked at just in case it craps out! anyone else have this issue?
Old Sep 3, 2010 | 03:24 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
"Too aggressive of a tire"?!?!
Have them do the 3x ATF drain/fill. If that doesn't work, also have them change out the tranny pressure switches.
You can always call ACS/BBB if they're not cooperative, but do not let them give you the run around.
Old Sep 3, 2010 | 03:28 PM
DaddysOnehotAck's Avatar
Yeah sounds like they giving you the run around with that tire non-sense! I mean WTF??
Old Sep 3, 2010 | 03:30 PM
johnc04's Avatar
Thanks, I am pretty sure tires don't control gears!!!
Old Sep 4, 2010 | 09:48 AM
I hate cars's Avatar
Do a search. There's a ton of info on the issue you're having. There's a thread like this every week.
Do a fluid change with Redline racing and replace the 3rd and 4th gear pressure switches. Problem solved if you don't wait too long. If you wait too long you will need a new transmission.
Make sure to tell the dealer how full of BS they are once you fix the problem.
TypeS860
Jan 10, 2026 11:11 AM
knight rider
Mar 4, 2016 08:59 AM
joflewbyu2
Oct 8, 2015 11:16 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
