Transmission Shutters!!!
...04 Tl auto. Not a crazy shutter but it happens. Seems like it doesn't change gears as smoothly as it should. 73,000 miles on it. I just bought it in June. Took it to the dealer and they re-produced the shutter and said I had too aggressive of a tire on the car. I am going to take it in again and document each time I tryed to get it looked at just in case it craps out! anyone else have this issue?
Do a search. There's a ton of info on the issue you're having. There's a thread like this every week.
Do a fluid change with Redline racing and replace the 3rd and 4th gear pressure switches. Problem solved if you don't wait too long. If you wait too long you will need a new transmission.
Make sure to tell the dealer how full of BS they are once you fix the problem.
joflewbyu2
10-08-2015 11:16 AM
