Transmission issue?
Old May 28, 2011 | 05:43 AM
paperboy42190's Avatar
Transmission issue?
so i've been on this forum long enough to know the importance of changing the atf and pressure switches. when i bought my car it had NO issues with the transmission whatsoever. the prev owner did routine honda z1 atf changes.
so i wanted to treat my car right and i have done the redline type F racing fluid flush, it made it shift faster but overall still not much difference.
then i did the 3rd and 4th gear pressure switches 2 weeks ago. ever since then i have noticed my transmission slipping between gears occasionally and occasionally shakes hard during downshift when braking to a stop(i think this is the shuddering gears i read about) in Drive. havent noticed the shuddering when shifting manually yet.
i noticed NO improvement in shifting with the pressure switches, but it does respond faster to shifting in manual mode.
/end rant
Old May 28, 2011 | 05:47 AM
and yes, i triple checked which pressure switch goes where during the install.
Old May 29, 2011 | 08:22 PM
dzionny_dzionassi's Avatar
i bought my switches, but reading all these threads... People change their switches and sudden they have problems with transmissions.
Did you try to reset ecu?
Old May 29, 2011 | 08:33 PM
rkan121's Avatar
When I changed mine they somehow got loose, and dripped ATF slowly. Eventually my tranny slipped for a day. I took it to the dealer and they fixed the crush washers and now everything is great. I guess if you have checked all this, maybe try taking it to the dealer.
Is your car throwing a code?
Old May 29, 2011 | 10:27 PM
im not leaking any atf, its all dry around the area and atf fluid level is full on the dipstick. and no codes at all. i've noticed the slip is only 2-3 shift, whether its in manual mode or drive. happens everytime.
Old May 30, 2011 | 11:11 AM
chayos00's Avatar
have you tried putting your old switches back. maybe u got a bad switch.
Old Jun 1, 2011 | 10:15 PM
What would you do if...?
What would you do if your transmission was slipping on the 2-3 shift? and you have 82k miles so warranty is out of the question. its the same slip as shown in this vid: http://www.youtube.com/watch?v=mrGINBbb3Fc&feature=channel_video_title
whats annoying is that if i gas it more before the slipping is done, it will cause the car to jerk a bit. doesnt slip when its past 5k rpm though.
keep driving until something more serious happens?
swap out the transmission asap?
already done redline type F fluid flush and 3rd and 4th gear pressure switches.
Old Jun 1, 2011 | 10:18 PM
sell the car?
Old Jun 1, 2011 | 10:27 PM
aIRpeACE's Avatar
if that's not a big problem, i will leave it there.
Old Jun 1, 2011 | 10:31 PM
if it doesnt get any worse im fine with leaving it like that. no one notices it except me since im the driver. but would this be a sign my tranny might be on its way out someday?
Old Jun 2, 2011 | 04:18 AM
azzyork's Avatar
I have an 05 tl that started slipping around the same mileage. First i asked around if someone can help me do the 3x3 transmission drain and fill, Scott on the forum helped me out but that didnt work. So i did a rebuild with 24k warrenty/2 years which ever comes first, no more slipping and so far im happy.
Old Jun 2, 2011 | 04:24 AM
where did u have the rebuild done at? and how much did it cost?
Old Jun 2, 2011 | 04:38 AM
azzyork's Avatar
Shop in Whitter, cost was $1300.00 here is the website http://atlastransmissionplus.com/ tell him simon with the gray 05 acura tl sent you.
Old Jun 2, 2011 | 05:19 AM
how long did you have the slipping for? does it get worse over time? what will happen if i ignore it?
Old Jun 2, 2011 | 10:01 AM
azzyork's Avatar
Car was purchased on march 2009 with 79k miles. slipping started slowly within 4 to 5 months, from my personal experience it got worst (not trying to scare you) beginning of 2010. I ignored it thought maybe I'm tripping then one rainy day on April 2010 going 30MPH or 40MPH my rpm shoots up to 5 or 6, my guess is something must have screwed up bad in the tranny because that day it didn't drive the same. There was time it would slip around 20MPH then 15MPH 10MPH then the bam i cant drive it, stepped on the gas and nothing. Had it towed to my parents house since they have a drive way and i drove my Nissan sentra til i did the rebuild in June. So as far as does it get worst? For me personally, yes and this may happen if you ignore it. save money just in case....
Old Jun 2, 2011 | 01:02 PM
csmeance's Avatar
put your old pressure switches back in and see if it fixes the problem. The TL-S uses a different transmission so it is very possible that you ordered the wrong parts...
Old Jun 2, 2011 | 02:35 PM
VanyDotK's Avatar
subscribing.. I'm trying to figure out which pressure switches I need for my TL-S
Old Jun 2, 2011 | 06:29 PM
I was aware of the possibility that i get the wrong parts or putthem in the wrong place. I triple checked the part numbers on my receipt and the packaging on the switches and they all matched correctly. However i will try puttig the swithes back next weekend when im done with finals in school. Im not trying to blame the problem on the switches though, perhaps my transmission was already on its way out and it just coincidentally happened soon after i did the switches.
Old Jun 2, 2011 | 07:45 PM
azzyork's Avatar
keep us updated, worst case scenario you give me your car and ill give you mines...
Old Jun 2, 2011 | 08:17 PM
This is the picture the parts i bought. paperboy42190 did you get same parts for your Acura TL-S? Where your sensors were made? I heard there are some made in USA and others in Japan. I am debating right now should i change mine, since you had no problems before you did your swithes.
Old Jun 3, 2011 | 12:49 AM
here is a copy of the receipt from the dealership i ordered the aprts from:
28610RKE004 SW, AT OIL PRESSURE 1 $32.34 $32.34
90471PW7A00 GASKET 10MM 3 $1.85 $5.55
28600RKE004 SW, AT OIL PRESSURE 2 $33.58 $67.16
Old Jun 3, 2011 | 01:21 AM
azzyork's Avatar
you can try that route, cheapest way. buy the switches again, worst can happen it wont work. better than 1000+....
Old Jun 6, 2011 | 03:40 AM
anyone have an explanation as to why the slip only happens in midrange rpms? under full throttle the shift from 2-3 is solid.
Old Jun 6, 2011 | 01:55 PM
csmeance's Avatar
Like I said before, try putting in your old switches. If that doesn't help you might want to try adding some Redline D4 fluid to the mix and see if it helps. It may just be that without the Friction Modifiers and some of the other components the transmission isn't functioning properly.
EDIT: when you replaced the switches some fluid was supposed to leak out. Did you refill the fluid to the right level? Check the fluid level and make sure you didn't over fill it or underfill it!
Old Jun 6, 2011 | 08:02 PM
yes a bit of fluid leaked out but it was probably only like a tenth of a quart and the fluid level on the dipstick was unchanged so i didnt bother adding more fluid.
i will trying putting the switches back this week. i had a lot of work for school recently so i havent had time to do it.
Old Jun 6, 2011 | 08:15 PM
1islandparadise's Avatar
I hope u get it fixed. Kinda making me second guess getting another TL.
Old Jun 8, 2011 | 08:04 AM
dam it! i was just on my way to put back the old pressure switches...then i couldnt find them! i seriously thought i had saved them in a box but apparently i must have left them in the trash box after i took them off the car.....ARG! what should i do now?
Old Jun 9, 2011 | 09:12 AM
Bump
Old Jun 12, 2011 | 06:30 AM
Bump
Old Jun 12, 2011 | 10:50 AM
chayos00's Avatar
Bump
As in the video, which is from my car. Acura changed out my tranny for this issue. It would slip faithfully up till about 4.5K-5K then it would grab solid after that.
Honda will charge around 5k for the tranny. If you get it fixed I don't think I'd put in the Type F fluid, stick with something tamer like the D4.
Old Jun 12, 2011 | 04:10 PM
mindanaomoro's Avatar
Paperboy, you mentioned it was working fine when you have the Type F. With the old switches, I would just get another switches and put them on and observe.
Old Jun 12, 2011 | 09:24 PM
TheChamp531's Avatar
Chapter Leader (San Antonio)
You sure you didn't install them incorrectly?
Also, I'd recommend just re-buying them from AckTL05 and doing it once more, but change out the filter this time.
I seriously doubt that the fluid and/or sensors are causing this slippage, maybe installation.
Old Jun 12, 2011 | 10:53 PM
usmarinedelta's Avatar
Honestly, I think it's the fluid more than anything. I did my switches first and there was no noticable improvement. After the fluid my car shifter a tad harder which I think in my own theory is that it puts more shock to the moving parts and may cause a bit of damage whereas smooth shifting limits the feel and shock. Like chayos, his thread said he started experiencing problems after his fluid change resulting a new tranny.
Old Jun 12, 2011 | 11:06 PM
csmeance's Avatar
even though there is a shock on the components, the type F fluid allows for a quicker and firmer shift. Those smoother shifts are actually worse because the parts grind against each other to create that smooth shift. The quicker firmer shifts are caused by the parts meshing into each other very quickly.
The problem with most fluid changes is that the old fluid wore the transmission down to the point where the particles and pieces in the fluid are the only thing keeping the transmission running. Once you put new fluid in, the worn pieces inside the transmission can't mesh together anymore and work.
That is precisely why I suggest not to do a 3x3 in one day and to do it over a period of time and save the old fluid. If the car starts acting rough, drain out the current fluid and put back in the old fluid.
Old Jun 12, 2011 | 11:10 PM
i did the installation myself i know what im doing, all it is, is screwing it in and tightening it then put the harness back. what could have gone wrong?
Old Jun 12, 2011 | 11:11 PM
however the chance is having a bad switch is low but not impossible, but the chance of having a bad tranny is probably greater than the chance of having a bad switch. maybe i'll get new switches one day...
Old Jun 12, 2011 | 11:37 PM
I forgot where the thread is, but someone put the 3rd sensor in the 4th and so on. Something like that
Old Jun 12, 2011 | 11:52 PM
and what happened? was it slipping transmission in midrange rpm?
Old Jun 13, 2011 | 08:31 PM
just change oil to D4....
Old Jun 29, 2011 | 02:20 PM
i think i notice the 3-4 shift slipping a little too now. only in midrange rpms too, just like the 2-3 slip. for now, the 3-4 slip is only like maybe 150 rpm, so hardly noticeable.
seems like my tranny is getting worse, if i gas it during the slip(which is about 1.5 seconds) it will jerk the car as it attempts to switch back to 2nd gear.
