Transmission fill plug
I'm trying to remove the fill plug using my 3/8" extensions but it's not coming loose. It is starting to strip it out. Is there a better fitting tool that goes in there?
And does anyone know the part number for that bolt in case I need to order one? I'm trying to find it on acuraoem.
rockstar143 (12-21-2017)
Latent car nut
From the top I had to use a half-inch six-point socket a long half-inch extension, and a breaker bar to free mine up; even still there was plenty of twist in the extension before it broke loose.
I did spray pb blaster on it. I took it to a shop that's less than a mile from me. They loosened it up and then I asked them to snug it up. I'm going to order the bolt and wait till it arrives before I drain it.
According to the schematics https://www.acuraoemparts.com/auto-p...er=90081pwt000 it is part #19 but it is labeled a drain plug not fill. Are they the same part for both fill and drain?
I want to know for sure so I can order two to have, just in case.
justnspace (12-19-2017)
Latent car nut
Yes, same part for both plugs.
Edit, I *think* part number 27 is the overflow bolt; remove this when you fill, and when MTF starts leaking out of this hole, you're full.
We Are Venom
pb blaster and a breaker bar!!!! 19mm bolt on the top! Make sure to move the clip thats connected to the fuse box or move the fuse box completely, then get some leverage! I used this https://www.harborfreight.com/12-in-drive-25-in-breaker-bar-67933.html]http://I used this https://www.harborfreight.com/12-in-drive-25-in-breaker-bar-67933.html[/url] with an extenstion.
It's not a 19mm bolt. It has an opening for a 3/8 ratchet.
I make my own brakes bar. I put a deep well socket over the end of my 3/8 ratchet and a long extension in the deep well socket.
How do you lay down and brake loose the top fill plug, the one below the battery? The issue wasn't that I couldn't get enough leverage but that the extension would rise up from the bolt and it was starting to round it out. The guy at the shop, hammered his extension in. I didn't think that would help, but it did.
We Are Venom
My bad, you are talking about the bottom drain bolt. Haven’t had a problem with any of my 3/8 ratchets....i didn’t use an extension because i was under the car.....but i did use a breaker bar. Try getting under there and just sticking the ratchet in with a break bar. You shouldn’t be using a socket at all. Just put it in.
OP has a Manual transmission.
That would have been an important piece of information to include
On the Auto's, it's a 19mm bolt for the fill and a 3/8" ratchet for the drain.
LGcbp8 (12-21-2017)
What signature?
I also had to hammer the extension on to get it loose. The little ball sticking out of the 3/8 drive (the thing that normally holds the socket in place) was causing it to slide out of the plug. Whacked it a couple times with a mallet and that was enough to wedge the end completely in place.
Joecop67 (12-22-2017)
Finally got a day that wasn't freezing, snowing or raining, so I put in the synchromesh. Let's see if that helps the 3rd gear pop out.
Good thing I bought 4 quarts. It took all of it.
Latent car nut
Yikes! You put in too much, you should only put in 2.3 quarts (i.e. 2-quarts 10-ounces). You need open the overfill plug and let the extra drain out.
horseshoez (01-10-2018)
Latent car nut
Seems to shift a lot smoother but then again, it may just be expectations after reading all the praises the synchromesh gets on here.
I do have a question, can this be used on other manual cars?
Latent car nut
I had a 2009 Mazda3 which I used as a long distance commuter as well as the car I taught my son to drive a manual transmission. It had a second and third gear grind issue and Synchromesh Friction Modified fixed that one as well.
It's been over 1 month since I've put the GM Symcromesh fluid in and I am surprised.
Before that I would have almost daily 3 gear pop outs. Now, it hasn't happened once since the fluid change.
Amazing.
Amazing.
Latent car nut
Rotary4life
1G CL Problems & Fixes
02-03-2009 12:03 PM
