Transmission external filter replacement?
Old Jul 31, 2023 | 01:51 PM
Peter Gozinya's Avatar
Peter Beater
Hey TL fam... First let me apologize for the length of this post but would appreciate advice... so I was looking up info on transmission fluid change and I stumbled across an article on Acurazine (link below) that references an external filter. I had never heard of that and neither had a lot of others that I've talked to so wanted to get your guys input. I did the fluid exchange before and simply drained then refilled. This one I found today shows the "external" filter which is accessible taking out the air box and unbolt the ATF inlet line bolt, pull out the filter (multiple YouTube videos I watched and they were all filthy and basically crumbled) so put a new filter in. You can buy a kit that has the filter, o-rings, everything you'd need to replace it... Anyways, do you guys replace this? I've read it's only to keep the fluid clean which is different from the main filter which is internal and that's the main one that if it gets clogged it causes the transmission to fail. I have a buddy who is a mechanic out of his home and he said Alldata software he uses doesn't even mention it. Thoughts on this?
https://acurazine.com/how-tos/a/acura-tl-2004-2008-how-to-change-automatic-transmission-fluid-and-filter-423879
Old Aug 4, 2023 | 03:45 AM
vpasla1's Avatar
Replaceable on the 04 to 06, not existent on the 07 to 08.
Should replace. Could probably go a decent internal between changes. Definitely change the spring and all the other parts as well.
Old Aug 4, 2023 | 11:57 AM
Peter Beater
Thanks for the reply and recommendation!
losiglow
Mar 31, 2025 09:40 PM
RandyMarshRules
Feb 16, 2019 02:42 PM
Skipswift
Feb 7, 2019 07:16 PM
JayhawkRX
2G TSX Problems & Fixes
Dec 23, 2018 09:34 PM
eralimited57
1G RDX DIY & FAQ
Jan 14, 2017 11:32 AM
