Transmission draining 3x1, 3x3, 3x?
Hi all, I have been reading about the 3x1, 3x3, 3x? flushing of fluid. Why is there no way to drain off the old fluid from the converter? It seems like a monumentally bad design would be an understatement. To get to 97% you have to spend 300ish and drop it 9 times? This is seriously the only option? ... sorry just in slight disbelief, thanks in advance for your help and thoughts.
Very few manufacturers have a drain on the converter. Ford was the only one back when I did it when you could pull a plug on the converter and drain it too.
Most of the time even the transmissions with a removable pan get the equivalent to a drain and refill when you ask for a service. You have to ask for a flush to get more than just a drain and fill.
You can swap all of the TLs fluid at once using about 8-9 quarts by using the cooler line method. I've done it a couple times to my TL when I wanted to try a new fluid without having the old fluid mixing and contaminating the results.
And where is the coolant line method? I get the importance, but without complete removal u dont really know if its doing any good without skewing the results. And $100 in fluid is $100 in fluid haha
All you need to do to get you where you need to be is a 3x3. That is 3 times, not 9 times and at the cost of 9 quarts of the ATF of your choice. Do a 1x3 spaced out like every other oil change and your good. Or disconnect the fluid line and stick the suction end into a vat of ATF and the discharge side into a waste bucket and start car.
Of course you have to do a drain and refill before starting it up with the cooler line disconnected. With the cooler disconnected, the old and new fluid won't mix while the engine is running and when you get to the new fluid, the discharge fluid transitions from old brown fluid to bright red in just a second or two. It's obvious when you've gotten the old fluid out.
Thanks vlad, I found that shortly after I posted. @Superunknown, 3x3 doesn't get your old fluid out completely. You are simply going on a dilution method, not removal, so it would be exponentially higher than 9 quarts 3x3, more like 27, 3x9 before you actually got 97% of the old fluid out of the rest of the system. 3x3 I think puts you at 76% there are other threads about the math behind it. Thanks again to all who helped.
Someone calculated in one of the many other trans fluid threads that 3x4 got you up into the mid to high 90 percentile change rate. In other words 12 qts.
Here is the thread... see post #4
https://acurazine.com/forums/showthr...on+change+rate
MetalGearTypeS
08-29-2016 08:28 PM
