Transmission
Old Jul 15, 2019 | 04:39 AM
9.del's Avatar
8th Gear
Transmission
I Recently Bought An 07 Acura TL
I Test Drove The Car Now Problem
I Brung The Car To A Shop To Get New Fluids And They Show Me That The Transmission Is Melting Or Something
A Few Days Later I Start The Car, It Turns On But When I Shift It Into Drive Or Reverse The Car Doesn’t Move It Just Revs And The Rpms Go Up On The Dash
Anyone Have Any Idea What The Problem Could Be ?
Also Should I Just Replace My Tranny Or Rebuild It ?
Old Jul 15, 2019 | 10:29 AM
losiglow's Avatar
That looks like JB Weld. Maybe they had a leak and thought that would fix it. It may not be related to the transmission not shifting.
Is the transmission fluid at the correct level?
Also, you don't need to capitalize every word.
Old Jul 15, 2019 | 02:13 PM
Jackass's Avatar
1.) What is the trans fluid level?
2.) What is the condition (color/smell) of the trans fluid?
3.) Check the axles to confirm one isn't snapped
4.) Does the dash indicator flash or properly indicate what gear is selected?
Old Jul 18, 2019 | 09:20 PM
9.del's Avatar
8th Gear
I Filled It But It Leaked Out
Also Found This Under The Car
Old Jul 19, 2019 | 09:30 AM
GhostTL09's Avatar
OP you found that piece where under the car? When and where did you purchase the car? Dealer, private seller? I'd hate to see a black blob on my tranny.
Old Jul 19, 2019 | 10:11 AM
Jackass's Avatar
Where did it leak from? Sounds like there are for sure structural issues with the transmission if the fluid is escaping that quickly. There are plenty of threads talking about transmission replacements
Old Jul 21, 2019 | 07:04 PM
9.del's Avatar
8th Gear
Not Really Sure Where You Leaked From , I just Know I Put the Fluid In I Came Back The Following Morning And Saw A stain under the car checked and it was empty again
when I looked up the part number it Came Up as something for the drive shaft assembly
Today I started the car put it into gear and it just rev’d like it regularly does but when I put it into park it made a grinding noise
NighthawkBlue
2G CL Transmission Recall Q & A
141
May 12, 2016 10:16 AM
tommyt1777
Dec 25, 2009 08:38 AM
earthbound741
Sep 30, 2009 04:34 PM
paliknight
Sep 15, 2008 01:42 PM
sonicleo
Mar 26, 2005 11:08 PM
