Transmission
Old May 12, 2013 | 12:45 AM
Mahmoud Hussein Moussa's Avatar
Transmission
2004 acura Tl with 196k.transmission works fine if car is cold once it start to warm up transmission starts to slip .. does any body know why it does that? how can i fix that?
Old May 12, 2013 | 12:52 AM
One_silly_wabbit's Avatar
Put a new transmission in it. or get the old one rebuilt, those are Signs of a failed trans bro
Old May 12, 2013 | 07:53 AM
Iaco's Avatar
Try changing the trans fluid first before doing rebuild. Read posts about what atf fluid to use.
This happens when the clutches/bands wear out... and need to get rebuild, or your fluid is low (but it only does it hot so your level is prob good).
I have an older Accord with the same issues and putting in DW1 helped alot, apparently redline racing atf is better for this though. You may be able to get 10-20k with this.
knight rider
Mar 4, 2016 08:59 AM
joflewbyu2
Oct 8, 2015 11:16 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
