trans problem
Old Apr 9, 2019 | 11:11 AM
Joeslow's Avatar
6th Gear
trans problem
This morning on my way to work I stopped for gas. When I went to leave I did not have Drive or reverse. It finally was able to move under its own power but shifting very weird and will just stop pulling the car. I did the ecu tcu reset drove okay for 1 mile then same thing. It’s a 2006 with 129k. Trans had a three x three change at 75k and 105k, not because of problems just being proactive. Any ideas on what would cause this..... one minute all good to all bad?
Old Apr 9, 2019 | 11:13 AM
Have you done the pressure switches?
Old Apr 9, 2019 | 11:19 AM
Joeslow's Avatar
6th Gear
No would that cause no reverse or drive?
Old Apr 9, 2019 | 11:21 AM
Not necessarily, just trying to rule out what kind of maintenance was done. Sometimes not being able to get into gear is associated with a broken axle as well, can you inspect to see if there's any issue there?
Old Apr 9, 2019 | 11:23 AM
Joeslow's Avatar
6th Gear
Both axles are fine
Old Apr 9, 2019 | 05:31 PM
Joeslow's Avatar
6th Gear
Pulled up code p0741. Torque converter not locked or locking. Does anyone have part numbers for pressure switches for 06 TL. I will clean and ohm test solenoid for torque converter
Old Apr 9, 2019 | 05:32 PM
https://www.google.com/search?q=site...hrome&ie=UTF-8
if you do a search using that code, you'll see that it typically means the demise of your transmission and switches won't really help.But here is the DIY for it nevertheless:
https://acurazine.com/forums/third-g...2006-a-729149/
Old Apr 11, 2019 | 01:29 PM
t-rd's Avatar
The torque converter clutch (TCC) is gone or worn out. It needs a rebuild at a trans shop, which means dropping the whole thing to get it done. I just did this last year on my AV6, but I caught the problem before the code came up.
tarponman85
Nov 3, 2007 04:03 AM
JUBIE
Jan 8, 2006 11:38 PM
Southern
Oct 11, 2004 07:29 PM
KrZyTypeS
2G CL Transmission Recall Q & A
Jul 26, 2004 12:09 PM
