TRans code P0757- Shift Solenoid Valve B Stuck ON
Old Oct 30, 2010 | 10:14 AM
PCweber's Avatar
Wife's car got this code, cant clear. Out of warranty. Any info/ help would be great. It is down hard. Thnking I will just try replacing the dual shift solenoid unit on top of trans.
Old Oct 30, 2010 | 12:51 PM
I hate cars's Avatar
I'm sure someone else will chime in with exactly which one is shift solenoid B but out of curiosity, is it driving normal?
Usually it will only have one or two gears when one of the solenoids go out.
First step would be to find which plug it is and check the connector.
Old Oct 30, 2010 | 01:59 PM
nfnsquared's Avatar
Old Oct 30, 2010 | 06:32 PM
PCweber's Avatar
Ends up one of the output half shaft drive axle seals failed and dumped fuid out. I filled it and it runs fine but has a steady leak out of one half shaft. Anyone know a parts breakdown link that shows the trans case output shaft seals?
Old Oct 30, 2010 | 07:20 PM
nfnsquared's Avatar
http://www.acurapartswarehouse.com/P...gPicture=False
Old Oct 30, 2010 | 08:26 PM
PCweber's Avatar
I dont see anything here showing the outputs for left/ right axle shafts and the seal for those?
Old Oct 30, 2010 | 08:33 PM
The seal is in that diagram, I just checked it. Keep in mind that the seal can be damaged when you have bad diff bearings and other things too.
Old Oct 30, 2010 | 08:42 PM
PCweber's Avatar
Which ref. # or part # is the left or right axle output seat? I am totally missing it if it is there.
Old Oct 30, 2010 | 08:49 PM
#20. The diagram is not very good, you would have to rotate it 180 degrees to see the section of the trans that it goes in.
mada51589
Jan 9, 2025 04:40 PM
jamestheunderdog
Jul 19, 2016 07:58 PM
ibGTV
Sep 28, 2015 03:40 AM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
DS2000TL
Sep 9, 2015 09:26 PM
