6MT/TL-S LSD oil?
Old Oct 30, 2010 | 04:22 PM
o4Komodo's Avatar
Rev High; Drive Happy
6MT/TL-S LSD oil?
So, I was browsing through some magazines and saw an ad for "LSD Oil" and thought, "wait... they have those?". Well, time to let my inner noob shine.
After a few quick google searches turns out there is such a thing.
So, my questions are,
at what intervals should the LSD oil be changed? And when do we know we should be changing the oil? My TL is at roughly 150,000KMs... I don't know if the LSD oil has ever been changed [from previous owner or from dealership].
And lastly, what is a good oil to change it with?
Old Oct 30, 2010 | 08:13 PM
o4Komodo's Avatar
So, I'm sitting here, thinking of the possibilities...
Does the LSD just share tranny fluid?
I'm confused though cause I see things about 'LSD oil' then I see "LSD additives".
Old Oct 30, 2010 | 08:47 PM
I hate cars's Avatar
The LSD fluid or additive is just a friction modifier to keep the LSD clutches from chattering around corners. I've never looked at a TL's LSD but I don't think it uses clutches or cones like many muscle cars use. If it's not a clutch/cone style you don't need the additive.
The trans shares fluid with the diff. Do not put this additive in the trans as it can reduce the holding power of the transmission's clutches and cause them to slip.
Just to clarify, some oils come with the FM already in them and sometimes the FM is sold in a small tube to add to a non FM fluid.
Old Oct 30, 2010 | 09:26 PM
o4Komodo's Avatar
Ahhh okay. Thanks a lot IHC.
That makes things clearer, somewhat.
I guess the LSD/Tranny is fine with just the GM-synchromesh tranny fluid then. Thanks again!
Old Oct 31, 2010 | 11:03 AM
SouthernBoy's Avatar
Registered Member
The LSD used in the 3G TL is of the helical type and therefore uses no clutch packs. And it is only offered with the manual transmission as I'm sure everyone on this site already knows. It is part of the differential assembly and is packed into the transaxle case so it is lubricated by the same fluid as the transmission gear sets.
IBankMouse
Jun 13, 2020 12:53 PM
spudweb
May 22, 2016 02:39 PM
Thuneau
Oct 3, 2015 04:19 PM
jubikej
1G RDX Problems & Fixes
Sep 30, 2015 01:13 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
