Tranny fluid HELP!!!
Old Jul 8, 2013 | 03:27 PM
jaw5983's Avatar
Unhappy Tranny fluid HELP!!!
okay so I changed the tranny fluid in my automatic tl, and I got out over 4 qts, and I put back in about 3, and on my dip stick its looking way overfilled, idk how but it looks like it is, im checking my fluid with the engine running and with it in park, is this the correct way???
Old Jul 8, 2013 | 05:12 PM
Jesstzn's Avatar
Did u drive it first before checking?
Old Jul 8, 2013 | 05:31 PM
dannyz's Avatar
TLicious Type S
The correct way to check the transmission fluid is to ensure the engine is fully up to operating temperature, shut it off, wait 60 seconds (and before 90 seconds), then take a reading on the stick. The fluid level needs to be between the two small holes.
Obviously, if you have just done a drain and fill, drive the car through all gears, including reverse, before taking the reading.
Old Jul 8, 2013 | 05:38 PM
Will Y.'s Avatar
Registered but harmless
Originally Posted by jaw5983
...im checking my fluid with the engine running and with it in park, is this the correct way???
No-- after the engine and transmission have run up to normal temperature, you should park somewhere level, shut off the engine, then wait 60 seconds before checking the transmission fluid.
Yeah, whatdannyz said...
Welcome to AZ.
Old Jul 8, 2013 | 11:29 PM
I hate cars's Avatar
Engine off car level fluid warm, by the time you pop the hood its fine to check it no reason to wait. If you wait too long converter drainback will raise the level in the sump if the check valve leaks.
Old Jul 9, 2013 | 08:31 AM
Project_CLean's Avatar
MMkay.
Man,you're just causing problems all over your car .lol
Double check the fluids as these guys instructed before you panic. Also,What kind of fluid did you use? you didn't use any additives did you?
SidhuSaaB
May 30, 2020 12:40 AM
LeVeL
Oct 18, 2015 04:19 PM
lanechanger
Oct 13, 2015 10:56 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
