Tranmission
Old Mar 19, 2015 | 10:24 PM
Cesarito's Avatar
Thumbs down Tranmission
hey guys... my car recently in the freeway did not let me accelerate at all... for a second before all that happened it felt like i was driving stick shift. downshifted hard out of nowhere going 80 mph and then into neutral... i was on the carpool lane trying to acerbate but it just would not acerbate.. i just the transmission dip stick and its between the lines and no check engine or VSA light came up... reverse works on the car... also i was able to drive it for a few few when it cooled down but then when the engine got warmer it didn't let me.. whats the problem here? transmission sensors? can you guys let me know please i hate being without a car ( sorry for my typos in advance) thanks
Old Mar 19, 2015 | 11:34 PM
Reaper76's Avatar
Sounds just like what mine did! Tranny is done! Torque converter got hot that's why it moved a little when it cooled down. Start getting estimates as a replacement or rebuild is most Likely inevitable.
Old Mar 20, 2015 | 12:39 AM
guitarplayer16's Avatar
It's toast - pressure switches won't bring it back to life.
Old Mar 20, 2015 | 11:20 AM
aIRpeACE's Avatar
sound like the tranny is on the way out. try to drain/refill once to see if that helps. otherwise, prepare to get a new tranny
Old Mar 20, 2015 | 12:22 PM
Cesarito's Avatar
There was no pop sound or anything big ...it shifts into gear correctly and smooth like always but doesn't really engage at all ... It only advances foward when the car is cold and when it gets hot it just revs the engine when I press on the gas as if it was in neutral
Old Mar 22, 2015 | 11:34 AM
flyromeo3's Avatar
while im sure you dont want to hear this. Start putting $ aside for a new transmission.
Old Mar 22, 2015 | 11:46 AM
truonghthe's Avatar
You will need a trany replacement or rebuilt.
Old Mar 22, 2015 | 12:10 PM
TacoBello's Avatar
Your car is an 04-06 isn't it? Sucks man. Those trannies shit the bed with little indication at times. You won't get any dash lights either, I believe. There's nothing inside the transmission to indicate to the ecu that the transmission is failing
Old Mar 22, 2015 | 12:23 PM
giraffe's Avatar
This makes me nervous about mine. Need to do the pressure switches and a fluid change asap.
Old Mar 22, 2015 | 12:26 PM
TacoBello's Avatar
It's a good idea. While there are many cases on AZ of the automatic transmissions failing, I'm not sure how prevalent of a problem this really is outside of our community. A friend's mom has an 04 auto TL that has yet to show any problems. I also question the maintenance regularity on that vehicle as well.
Old Mar 22, 2015 | 12:31 PM
giraffe's Avatar
That's true it may never happen, but with my garbage luck it probably will, so I'm going to take the precaution.
Old Mar 23, 2015 | 09:58 AM
flyromeo3's Avatar
your trans is slipping because your not getting fluid to the clutches.
Could very well be the Torque converter pump has failed. ( think its called a stator )
lookinco
45
Jan 30, 2007 09:32 AM
aprentice
Oct 1, 2006 05:54 PM
CL-S469
2G CL Transmission Recall Q & A
Aug 17, 2003 11:25 AM
Eskimo
Jul 30, 2002 08:21 AM
