Traction Control Light Always On
Old Nov 10, 2014 | 09:55 AM
Adambomb74's Avatar
Exclamation Traction Control Light Always On
2006 Acura TL, non-Navi. Alright, so on my way to work this morning my check engine light came on today. Got it into the shop (I work at a shop). The code came up as a cat deficiency. Which is no big deal, although I have about 5 other codes from different systems (SRS, body electrical, TPMS, etc) Everything was working fine so I cleared the codes. While clearing the codes, my traction control light came on (triangle with exclamation point), and stayed on. The Traction Control button does not do anything, and No codes are found while scanning. Any suggestions? I replaced the VSA fuses, but that didn't do anything. Anyone have any ideas? I have not checked other fuses, as I do not know which to check.
Thank you!
Old Dec 14, 2014 | 11:20 PM
cavitt423_UA6's Avatar
4th Gear
My vsa and traction control is always off. Button does nothing. Also have an abs and brake light on. My brake lights do not work AT ALL. if anyone resolves this issue. LET A BROTHA KNOW !!!
Thanks in advance
Old Dec 17, 2014 | 10:05 PM
Icemaninlv's Avatar
cavitt423_UA6 bad VSA under the hood, 40amp
Old Dec 17, 2014 | 10:07 PM
Icemaninlv's Avatar
vsa fuse my b
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
PortlandRL
Sep 14, 2015 12:01 PM
Charlespsu
Sep 2, 2015 09:54 AM
