Tpms
Old May 17, 2011 | 04:26 PM
amaniTL's Avatar
Tpms
After driving for a few miles the TPMS light keep coming on. Help me its annoying. I was thinking maybe one of the Tire pressure monitor things are not working.
Old May 17, 2011 | 05:04 PM
rkan121's Avatar
Check your MID on your dash board. Also it will tell you your actual tire pressure then fill up yours tires to the proper PSI. I have nitrogen in my tires and it doesn't fluctuate with temperature differences. Also try reading your car Manuel or searching on these threads ...............
Old May 17, 2011 | 05:08 PM
oneonlywgs's Avatar
The One
put some air in the tires & see what happens. if it comes up again, you might have a slow leak, (nail, valve stem)
Old May 17, 2011 | 08:34 PM
amaniTL's Avatar
thanks i checked and the front right tire is sayin 58 and the rest is in the 32 and 33.
Old May 18, 2011 | 12:22 AM
Bearcat94's Avatar
AZ Community Team
If the display shows a constant "58" or "---" you probably have a faulty sending unit on that wheel.
On start up all 4 show "58", but go to the correct measured pressure within about 5 seconds beginning on the right front, then right rear, then left rear, then left front.
Old May 18, 2011 | 07:58 AM
NSXTC's Avatar
Just drive...
Have that TPMS sensor checked on that wheel, it's either not setup correctly or it is faulty.
Old May 18, 2011 | 01:05 PM
amaniTL's Avatar
its is a constant 58 until the check tpms comes up.
Old May 18, 2011 | 01:06 PM
amaniTL's Avatar
ok i will get a sensor for that wheel and change it.Thanks guys
neuronbob
23
Jul 16, 2019 10:48 AM
bailey24
Nov 21, 2015 08:43 PM
johnalfa
Nov 5, 2015 06:44 PM
johnalfa
Oct 31, 2015 12:55 PM
RobbDizzle
Oct 15, 2015 11:16 AM
