TL won't start manual transmission
Old Jul 25, 2013 | 10:24 AM
Shipit's Avatar
Question TL won't start manual transmission
So the car will start when the outside temp is hot but if it has sat overnight in the morning it won't start, in the afternoon it will. I know the solenoid is not getting power at the s connection on the solenoid. I tested the starter cut relay and swapped with known good one I changed the starter OEM acura, and replaced the ignition switch, but I am getting the same problem as before no power at the s connection on the solenoid I have continuity on my wires under my dash. I also have continuity on the clutch safety switch as well so I don't think it is that
The car was recently at the body shop a lower ball joint failed and they needed to take the dash out to weld in a new panel before the car went to the shop there were no issues.
I am really at a loss unless there is another relay that could be blown but I have tested all of them and inspected every fuse grounds all look good inside and under the good.
Hope someone can help or has had the same issue and point me in he right direction.
Old Jul 25, 2013 | 01:46 PM
AndrewA's Avatar
Is the positive battery terminal corroded?
Otherwise, about the only think you haven't checked are the underhood fuses 22 (120A) and 23 (50A).
Old Aug 2, 2013 | 01:19 AM
Shipit's Avatar
I figured it out, the Lt. Green wire coming off the clutch interlock switch is loose going into the MICU (the grey box that has fuses and relays on it next to your left foot), probably happened when the body shop took the dash and MICU out to weld in a rocker panel.
If it keeps on being intermittent I will have to take it back to the body shop and explain to them what I found and hopefully they will fix it if not I will have to find a creative way to fix that 1 pin in the harness.
Old Aug 2, 2013 | 01:25 AM
Shipit's Avatar
Here is a look at what I am talking about.
Old Aug 2, 2013 | 03:27 PM
Majofo's Avatar
Glad I could help.
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
justin7779
Dec 25, 2015 10:33 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
asahrts
Sep 4, 2015 05:55 PM
