Headlights Stuck on High Beam 1 side
Old Aug 1, 2013 | 10:26 PM
adreano17's Avatar
On low beam, one is brighter than the other (left side), and I was like WTF. Turned on High beams and that side didn't change, but the other side got as intense in brightness as the left side.
Its like the left side is stuck on high all the time. Any suggestions?
Old Aug 2, 2013 | 12:55 AM
Acura_Dude's Avatar
David_Dude
Sounds like your "shutter" is stuck. It's not moving back into place.
Old Aug 2, 2013 | 08:01 AM
maharajamd's Avatar
That is correct. I just had this problem and I won't lie, it fixed itself after a couple of rapid bumps.
If it doesn't you can take the light off, take the bulb out, and carefully use a thin right angle pick to pull it back.
If you aren't following us, google how bi-xenon lights work.
Old Aug 2, 2013 | 08:06 AM
adreano17's Avatar
Shutter? This doesn't have anything to do with the harness does it? I kinda broke off my harness and jammed it back together. But there is no short on it.
Did anyone have a DIY for the tl specific? Or are all bi xenons the same that can have the same solution? Appreciate the help guys!
Old Aug 2, 2013 | 03:39 PM
nate_0022's Avatar
Land of 10,000 lakes
All Bi-xenon projectors are basically the same.
You should drive over a rough road to see if the shield will set back into place. Otherwise you will have to do as maharajamd said. Take the headlight off, pull the bulb out and stick a hook or something inside and pull the shield back.
Here's what the projector looks like pulled apart.
The shield flips down towards the lens to activate the high beam.
HairyMonkey019
Apr 22, 2016 10:50 PM
PortlandRL
Sep 14, 2015 12:01 PM
JnC
Sep 11, 2015 06:06 AM
theinsvnity
Sep 10, 2015 10:22 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
