TL-S Tail Light swap gone bad
Old Jun 16, 2009 | 11:28 PM
04_6SPEEDTL's Avatar
I mod my car in
Unhappy TL-S Tail Light swap gone bad
I just finished installing type s tail lights on my 04 base TL. Everything was working well, i stop off at a meet and my friend is like you have a tail light out. So i check and sure enough it was out. When my lights are on the tail light does not light up, it only lights up when i press the brakes. I searched the other forums and didnt find any problems quite like this so sorry if it is a re-post. I think that the problem is the wire from the LED board to the connector....any idea's what this problem can be?
Old Jun 17, 2009 | 03:07 AM
wasupdog's Avatar
My Garage not
it's the wire to the led board like you said. you probably have to re-install it making sure that the male and female connections are tight or check to see if a connector needs to be replaced if that doesn't work.
handsom-hustla
Nov 13, 2015 05:04 PM
wusty23jd
Sep 24, 2015 11:41 AM
Ny1718
Sep 11, 2015 09:21 AM
JnC
Sep 11, 2015 06:06 AM
brjones9
Sep 3, 2015 07:30 PM
