TL-S coolant temperature doesn't go beyond 25%
'08 TL-S 6MT
Could it be my temperature sensor gone bad? On a cold start, the needle hangs below the C and I noticed that it never goes beyond 25% from the C. It stays perfectly horizontal and parallel to the dash. I snapped a pic but not sure if you can see it(on my iPhone).
http://m.flickr.com/lightbox?id=6346303400
Jokerman
That is normal, you also have to remember that temp gauges dont always read excatly the same. As long as it doesn't go all the way up or dont move at all, i think you will be alright.
Early Shifter
If one is hot and one is warm/cool then your thermostat may be creating some blockage/stuck partially open.
Your warm temps don't look that accurate. I'll have to double check but I'm sure mine is somewhere close to the mid point (I'll take a snap at lunch time). This is after 5-7minutes of run time with the temps we've been having here in Toronto.
Jokerman
I guess my car may be messed up as well. I dont know, it has always been that way, stopping somewhere around 1/3 the way up. I dont know, i always figured as long at it doesnt stay at the bottom, my gauge is working, and as long as it doesnt go all the way up, the cooling system is working.
Stay Out Of the Left Lane
Received 1,245 Likes
There doesn't seem to be too much difference between the two posted pix (engine warm). My gauge seems more like jeeva86 and I have an 08 TLS.
Mau108 - you don't mention your driving conditions or ambient outside temperature.
I'll take a closer look at mine tomorrow.
i have a 08 TL-S and mine is also like jeeva's.. on my old 94 honda accord it would also hang around right below the middle line.. when it reached the middle something was wrong, for that car..
but i am curious to see everyone else's response because i always thought below mid was normal for hondas/acuras
EDIT:
I found a pic i took few days ago.. this was after 30+ minutes of driving, so it was fully warm
EDIT:
mine was after 30 minutes of driving and ambient temps were 5-6 degrees Celsius about 41 Fahrenheit.
Car was not moving when I took the photo (was waiting to turn left). I have a bluetooth obd2 dongle I'll get an accurate reading of my coolant temps today.
I noticed my needle was at the position I had original posted 10 minutes after starting up the car and driving.
My engine temp at idle after a 15 minute run on the freeway at above 100km/h (seems quite low)
While driving:
I could of sworn my Prelude's temps were always around 96-99 degrees celcius and it would kick in the fan at 100 (had a Scangauge hooked up to that car)
While driving:
i talked to my mechanic about this issue today, he told me the thermostat was probably stuck open on my car. and this also causes the heat to take longer to get really hot when you turn on your car.
and i did notice this was a problem on my car recently.
i was wondering if anyone else had this problem with their heat.
So I checked mine today both to and from work (actually Jury Duty this week ) which is 32 miles each direction and the temp gauge needle moves up to the 5th graduation just like jeeva86 and Will1688. It was 54F on the way in this AM and about 43F on the way home and yes it was colder on the way home than on the way in. Cold front moving in with rain, etc.....
Pretty sure my wife's MDX only goes up about a third as well.
'08 TL-S 6MT
So it seems like something could be stuck with mine since it never has gone above the 5th line. I'll try to check how hot the rad hoses are too tmr. I've only put the heater on once the engine is warm(5th line) and usually I put it a low fan speed so I can't comment on if it's as effective or not.
AZ Community Team
Received 7,771 Likes
Mine is more like mau's - a couple of tick marks below 1/2. Always has been.
'08 TL-S 6MT
I haven't done anything as well. It's pretty cold outside but I tried to touch the radiator pipes but it wasn't burning my hands :S. Not sure if I was touching the right pipes and it was freezing outside.
It seems like there's 2 marks. The area where mine and Will168 sits at and the one where Mau's at. I suspect you guys are fine since I'm not able to reach that point.
I think my fuel efficiency sucks because of this. According to the MID, I'm getting 10, assume this is 10.99, so make it 11. I pump for 50L usually but I've only driven < 450km :S.
MetalGearTypeS
08-29-2016 08:28 PM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
