TL key light flashing
Old Mar 16, 2016 | 06:45 PM
rabalero69's Avatar
3rd Gear
Unhappy TL key light flashing
i hope you can help me.. my 2005 tl key light is flashing i replace the inmobilization sistem the one thats goes on the key and still nothing battery is new..the alarm does not open door knobs or make any sound trunk is not working with the remote..remote has a new battery...so im goig to try to replace the ecm and last the key..fuses are ok in the engine bay and the ones inside the car..any advise what could be the problem??
Old Mar 16, 2016 | 11:25 PM
csmeance's Avatar
immoblizer needs to be paired/programmed to the ECM/ECU and also to the key. Same with the remote to the car.
Old Mar 17, 2016 | 07:56 AM
JasonK's Avatar
09 TL SH AWD /w TECH
This.
Old Mar 17, 2016 | 11:22 AM
rabalero69's Avatar
3rd Gear
the locksmith has come to reprogram the ecm and the green key still blinking...he made a new key i change the inmobilizer..so my last bet is the ecm...or i misssing something more?
Old Mar 17, 2016 | 09:53 PM
csmeance's Avatar
Maybe it's a bad sensor in the ignition switch that picks up the data/code from the key
Old Mar 17, 2016 | 10:49 PM
rabalero69's Avatar
3rd Gear
SO IT HAS ANOTHER SENSOR??? I THOUGHT IT WAS JUST THE INMOBILIZER... SO THAT SENSOR ON THE PICTURE COULD BE THE PROBLEM??
Old Mar 18, 2016 | 02:37 AM
csmeance's Avatar
Yes, Part no 14, Immoblizer unit:
COMBINATION SWITCH for 2005 Acura TL
Old Mar 18, 2016 | 02:48 AM
csmeance's Avatar
Flipster23
Norcal
262
May 4, 2023 02:47 PM
0utl
Jul 18, 2016 09:06 AM
Skier4lyfe303
Jul 13, 2016 03:53 PM
Tegfreak
Mar 4, 2016 03:02 PM
Bl4des14
4G TL Problems & Fixes
Feb 26, 2016 07:59 PM
