Tire rotation gone wrong!
Welll took the car in for B1 service. Oil change, tire rotation, and inspection. Well i marked my tires, and i checked when i came back home, and they didnt rotate my tires right. They didnt cross the front 1, to the back, and didnt cross the back ones to the front. They just put the front right tire on the rear right tire. And the left front to the back left tire. What could happen.
As far as starting a cross rotation, it certainly won't cause any problems, unless the camber/toe is out of specs, and that would be a problem on the first cross rotation anyway.
Incorrect way to rotate non directional tires.If one were to look at their owner's manual, it shows the rotation for both directional as well as non directional tires.
Tire rotation
Guys,
The manual tells you how to do it criss-cross for a reason. Tires that roll one direction get "cupped" and they have high spots. Eventually they get noisy and rough if left this way. Rotating them files down the cupped area because eventually you will be turning all of them the opposite direction.
On uni-directional tires you have no choice but my stock Michelins can be. My tires look great with even wear and run smoothly.
If your alignment is altered by winter etc., the tires that get roatated will get worn unevenly too, so bear this in mind.
I'm no expert, but this philosophy has served me well on all my rides.
QuickRick
QuickRick
Well, maybe I should've said, "Not surprised, they did the same thing at my dealer." I called 'em on it. They said that's the only way they do it - directional or non-directional tires. I was running stock MXM4 at the time, 9500 miles on the odo.
I continued that way (NOT cross rotating) for a couple of tire rotations. I noticed a little excess wear on the inner(?) edges, probably camber from the drop.
So, I figured I'd cross-rotate and hopefully even out the wear. BIG mistake. Tons of vibration and created/amplified rattles galore.
So, my suggestion is: do it one way or the other, but don't start out NOT cross-rotating, then later change your mind.
If alignment, front and rear, are within specifications as indicated by trear wear pattern, no abnormality should be expected, other than possibly a rebalance regardless of the time of cross rotation.
Just what I said about vibration with irregular tire wear, but you should have encounter a slight vibration even when moving from to back as the wear patterns on each corner is probably different in this case. Got to pay if you're going to play by dropping the car and not having it aligned into the proper specifications.
But "wearing them in" that way, then cross-rotating created an issue.
And that's my point: Do your rotation one way or the other, but don't change later on the same set.
Anytime a tire wears with an irregular pattern, it will cause a problem whenever it is rotated front to back or side to side because of the change in contact patch.
I'm finished.
