Hello everyone!
I have just taken on the task of changing my timing belt and water pump. Everything has been going great up until this point (we wont talk about how I almost lost my power steering pump bolts). I am putting my idler back on attempting to torque to spec via this thread, however the bolt does not stop spinning... I guess my question is really, "How screwed am I"? Is this a common issue or did I manage to totally mess something up?
Thanks a ton!
Josh
Thanks a ton!
Josh
zeta
close
- Join DateAug 2003
- LocationS. Florida
iTrader Positive Feedback100
iTrader Feedback Score(1)
Liked:2,202 Times in 1,772 Posts
Quote:
1) Is it possible that you accidently switched the shorter #7 (TB adjuster bolt) with the longer #11 (TB idler bolt)?Originally Posted by JoshJ5Hawk
If that is possible.
https://www.acuraoemparts.com/auto-p...ming-belt-scat
Quote:
2) If you did not accidently switch bolts #7 and #11 and you are using the correct sized bolts, are there aluminum threads coming out of the block after the #11 spins and you remove it?Originally Posted by JoshJ5Hawk
...or did I manage to totally mess something up?
I did indeed use the correct bolt, I made sure to keep them with what I took them out of lol.
Now that I took it out, yes, I do have aluminum shavings coming out
any way to retap that hole without pulling the engine or taking to to a shop?
