Timing Belt Idler Bolt Won't Stop Spinning
Hello everyone!
I have just taken on the task of changing my timing belt and water pump. Everything has been going great up until this point (we wont talk about how I almost lost my power steering pump bolts). I am putting my idler back on attempting to torque to spec via this thread, however the bolt does not stop spinning... I guess my question is really, "How screwed am I"? Is this a common issue or did I manage to totally mess something up?
Thanks a ton!
Josh
Thanks a ton!
Josh
If that is possible.
https://www.acuraoemparts.com/auto-p...ming-belt-scat
2) If you did not accidently switch bolts #7 and #11 and you are using the correct sized bolts, are there aluminum threads coming out of the block after the #11 spins and you remove it?
I did indeed use the correct bolt, I made sure to keep them with what I took them out of lol.
Now that I took it out, yes, I do have aluminum shavings coming out
any way to retap that hole without pulling the engine or taking to to a shop?
el.profe
Feb 20, 2020 06:26 PM
kaushiknair
May 15, 2013 02:44 PM
twoelectric
1G CL DIY & FAQ
Jan 19, 2013 01:20 PM
jdm_94-07TypeS
Sep 19, 2011 09:26 AM
