Temperature gauge only goes up when accelerating
Old Mar 27, 2021 | 10:02 PM
Deeguala's Avatar
Good evening guys, have an Acura TL 2007 125K miles. Recently just fixed up my car of a front end crash. Had it sitting for about 6-7 months. Haven’t been driving it a lot, but haven’t done any of the tunes up which are oil change, transmission drain, spark plugs, etc. Car has a brand new radiator installed & new fans. Temperature gauge only goes up 2-3 lines up halfway when accelerating at high speeds either on regular streets or the express way. No coolant leaks or any of that sort. Car doesn’t over heat when stationary or at regular speeds. Gauge goes up, but quickly goes back to normal readings after 5-10 minutes ? What can it be ?
Old Mar 28, 2021 | 08:52 AM
peter6's Avatar
Bad thermostat? Air in the system? Connect some scan tool, graph the temp and check how much it actually changes.
Maybe it only varies by couple degrees.
Old Mar 28, 2021 | 10:52 AM
horseshoez's Avatar
Latent car nut
I second a bad thermostat.
Old Mar 28, 2021 | 10:44 PM
Deeguala's Avatar
Bump, need more opinions.
Old Mar 28, 2021 | 10:45 PM
Deeguala's Avatar
I’ve gotten a lot of opinions & it’s all pointing towards the thermostat. Crazy how quickly & out of nowhere they can give out. Car wasn’t having issues 3 days ago.
gavriil
May 15, 2026 08:07 AM
oJVIurder
May 21, 2017 03:09 PM
GroceryGetter206
Jul 22, 2012 01:28 AM
Dice1947
Nov 15, 2011 03:32 AM
edouglas1
Jul 28, 2010 11:35 PM
