Tail Lights won't go off
Stage 1 Audi S5
Hey All
My sister took my old 05 TL and last night she came home and said the tail lights wont go off. I am going over to check it out but she said the brake lights go on and off just fine, the headlights and marker lights are out up front but the whole back is lit up. I had her disconnect the battery for 15 minutes and reconnect but no luck. It has been disconnected all night to save the battery and I am hoping when I hook it back up, everything is fine but just in case it isn't, what could this be?
I had installed the type S tails well over a year ago and never had any problems so I can't imagine it is them but...
it might be a faulty brake switch, but not 100% sure since when my brake switch went bad, I had no rear brake lights. Are the reverse lights on too?
Stage 1 Audi S5
well, i just came back and everything worked fine after i reconnected the battery. I have no idea why this happened but hopefully it won't again. I would like some more feedback tho, just in case it does
No the reverse lights wheren't on, just the running lights
rockyboy
12-06-2022 02:29 PM
handsom-hustla
11-13-2015 05:04 PM
wusty23jd
09-24-2015 11:41 AM
