Tail light problem
Old Jun 18, 2014 | 12:34 PM
JLsTypeS's Avatar
Tail light problem
I traded my tail lights to a member. I have a 2007 acura tl type s and he said his came off of a base model 2008 tl. So we traded and everything matches up except there isn't the plug for the brake light. I have two plugs connected to my car that both need connected to the turn signal and the brake light. His only came with the turn signal plug. What do I have to do to make these work?
Old Jun 18, 2014 | 02:53 PM
zsameer's Avatar
You are probably just missing the wire that goes to the LED board. Here is a link to the 08 base taillight assembly and the part you are probably missing is number 10 in the diagram. You can remove the Philips screws that are holding the LED board in place and you will see where it connects.Hope this helps.
http://www.oemacuraparts.com/auto-pa...peed-automatic
Actually the turn signal one just gets the bulb assembly screwed into the housing from what I recall so there should only be one wire ( number 10 in the link) with the light. Maybe upload a pic of yours so we can get a better idea of what you are missing.
Old Jun 18, 2014 | 02:58 PM
JLsTypeS's Avatar
Ok, give me a minute and I'll upload pictures of mine.
Old Jun 18, 2014 | 03:09 PM
JLsTypeS's Avatar
Here are the two switches that are connected to my car and that I unplugged from my tails before I traded them. The one on the right has the plug on the tails he traded me, but there isn't a plug for the switch on the left.
This is the picture of the back of the tail light that he traded me. It only has one plug that connects to the turn signal, but nothing for the brake lights.
And here is the back of the LED board.
Old Jun 18, 2014 | 09:26 PM
Popee's Avatar
Just want zsammer said your missing the wire that connect in the led
Old Jun 18, 2014 | 09:34 PM
wilztlxs's Avatar
TLX-S
I have two of those wires you need for the LED board, I just PMed you
rockyboy
Aug 4, 2024 10:35 AM
handsom-hustla
Nov 13, 2015 05:04 PM
wusty23jd
Sep 24, 2015 11:41 AM
Ny1718
Sep 11, 2015 09:21 AM
brjones9
Sep 3, 2015 07:30 PM
