tail light LED question
Old Jun 30, 2010 | 12:11 AM
mrconnecticut's Avatar
2004 Acura TL
when i press the brakes a couple of the lights don't light up.. what do i need to fix this?
Old Jun 30, 2010 | 11:43 AM
2004 Acura TL
bump bump i wanna get this fixed lmk
Old Jun 30, 2010 | 12:03 PM
2004 Acura TL
figured it out.. thanks everyone! close this thread
Old Jun 30, 2010 | 12:05 PM
instead of closing this thread, share with the rest of us what you did.
what were the symptoms in the first place, your first post was kinda vague.
was the LED circuit board out?
Old Jun 30, 2010 | 12:14 PM
dwb993's Avatar
You have 2 choices---Buy the part new from Acura or find one used (check with AckTL05).
Acura will not replace these under warranty as they are considered a bulb which makes it a "wear item".
Replacing it is not too difficult, but you have to drop the rear bumper to get to the bolts holding the tail light in. Check any of the tail light swap threads for pics and info.
One more note---be gentle with the board. I broke mine swapping in my TL-S tails. Don't force anything---if it doesn't seem to fit, take it apart and see why.
Good luck!
Old Jun 30, 2010 | 01:55 PM
2004 Acura TL
no just a couple of led's were out. i figured you have to get the whole led board now?
Old Jun 30, 2010 | 02:25 PM
dwb993's Avatar
Thats correct.
Like I mentioned, PM AckTL05. He does custom tail lights and may have one he can part with. I believe Acura wanted like $105 for a new one.
Old Jun 30, 2010 | 05:03 PM
2004 Acura TL
thanks.. but for some reason there working again after i took it all apart
Old Jun 30, 2010 | 05:07 PM
AMUA6's Avatar
ScoobyZINE
Weird..? Sounds like it might've been shorting out somewhere?
handsom-hustla
Nov 13, 2015 05:04 PM
wusty23jd
Sep 24, 2015 11:41 AM
Ny1718
Sep 11, 2015 09:21 AM
drewdeezy03
Sep 3, 2015 08:04 PM
brjones9
Sep 3, 2015 07:30 PM
