Sunroof Seal Replacement
Old Jan 31, 2014 | 12:15 PM
afo1201's Avatar
Does anyone know how to remove,replace the sunroof weatherstrip seal?
Old Mar 7, 2015 | 11:20 AM
jimmriley's Avatar
Jmr
How about anybody knowing how to reinstall or replace the sunroof drip channel seal. It just came loose and now the sunroof rattles.
Genuine Factory ACURA OEM Part
2004 ACURA TL - Base V6 3.2 Liter GAS
Drip channel seal- Sunroof - SEAL, DRIP
Part Number 70243SEPA01 -
Old Mar 17, 2015 | 12:25 PM
jimmriley's Avatar
Jmr
Correction to my earlier post. I incorrectly identified the rubber seal that came loose. I found out that the rubber seal that came loose came from the 70500SEPA01 (part number), air deflector, See diagram at "http://www.parkacuraoemparts.com/parts/2004/ACURA/TL/index.cfm?action=partDetail&section=BODY%20HARDWAR E&group=ROOF&subgroup=SUNROOF&component=Air%20defl ector&partnumber=70500SEPA01&vehicleid=175055&site id=215332" Item 14. This air deflector has a rubber seal that is press fitted into the base/bottom side of the air deflector. Apparently you cannot buy the rubber seal, you have to buy the entire unit which includes the rubber seal. I was able to press fit the seal back in which stopped the rattling caused by the air deflector bouncing around with the sunroof closed.
cycdaniel
Dec 17, 2019 10:58 AM
snorf
Nov 4, 2019 06:44 AM
yesSIR-S
May 13, 2016 05:42 PM
winkyyy
Sep 11, 2015 04:40 PM
iRaw
ILX Photograph Gallery
Sep 10, 2015 12:29 AM
