Sunroof doesnt close
Old Mar 26, 2019 | 04:04 PM
mazen222's Avatar
So when my sunroof is completly open (not tilted), and i press the auto close, it will go all the way to the end (minus 1 inch) and then re-open as if something blocked it.
I was able to close it eventually by repeatadly pushing the close button for fraction of seconds at a time.
I'll check the tracks make sure nothing is blocking them, but was hoping to hear your experiences on this matter.
Do you grease them sometimes? is there a motor reset/learning procedure that you guys tried before?
Anyways, just getting ready for summer after this long cold and gray winter.
Thanks!
MM
Old Mar 27, 2019 | 08:47 AM
Jackass's Avatar
I "usually" try to wipe the rails out once a year....kind of...as much as you can, and then spray a tiny amount of lithium grease on the tracks. I have never known the "appropriate" preventive maintenance for sunroofs. This is just what I have done over the past 20 years or so since every car I have owned since '97 has had a sun/moonroof. Then I use Shintsu grease across all of the seals.
Old Mar 27, 2019 | 11:50 PM
WDPanda's Avatar
If the auto close fails, you can half hold the button to manually close. You don't have to keep pushing it.
vietxquangstah
Sep 27, 2017 06:38 PM
jda123
May 22, 2011 08:49 PM
pimpravi
Sep 24, 2004 02:16 AM
Bananas
1G TSX Problems & Fixes
19
Aug 18, 2004 01:35 PM
