=( hood doesnt close all the way =(
Old Sep 22, 2004 | 10:16 PM
pimpravi's Avatar
I pimp an Audi A4.
well i installed my body kit today and we needed to jack up the front of the car so we found a spot underneath by the radiator.. well when we put it back down the hood moved up.. did my frame get shifted up or what? my friend told me it happpend with his car and he just hit it down with a rubber mallet.. what should i doooooo!
Old Sep 22, 2004 | 10:26 PM
hzm82's Avatar
umm, don't hit it with a rubber mallet. Are you sure you didn't leave like a screw driver or something under the hood and it's getting in the way of properly closing the hood.
Why did you jack the car up? It's easier to remove the front bumper to install it. Didn't you use the proper jacking points (look in the manual if you don't know where that is). If you use the proper jacking points, it shouldn't harm the car.....if you didn't.......hit yourself on the head.
Old Sep 22, 2004 | 10:39 PM
pimpravi's Avatar
I pimp an Audi A4.
nope no screw driver.. my car is lowered so it was a b$*%@ working down there.
has this happened to anybody else?
Old Sep 22, 2004 | 11:43 PM
pimpravi's Avatar
I pimp an Audi A4.
bump (need help)
Old Sep 23, 2004 | 01:52 AM
pimpravi's Avatar
I pimp an Audi A4.
thanks for the replys
Old Sep 23, 2004 | 02:45 AM
t0ast's Avatar
2Poor 2Furious
Take it to a reliable body shop and see what they say.
Otherwise, try and get a similar model TL and compare em. You should be able to figure out what's out of line.
Old Sep 23, 2004 | 03:22 AM
jayhawk815's Avatar
Well, I think it's safe to say that your frame is not at fault, unless you were EXTREMELY violent when installing your body kit.
Old Sep 23, 2004 | 05:49 AM
Lawaia's Avatar
Moderator Alumnus
^^That's was a mistake^^
If you placed the jack under the radiator support you most likely torqued the crap out of it and thus mis-aligned the hood latch. Take it to a body shop and have them check it out. Best case scenario is they bend the bulkhead back into shape. Worse case is changing the entire bulkhead.
Good luck....
Old Sep 23, 2004 | 08:42 AM
fsttyms1's Avatar
Good luck....
agreed! do what he recomends! that was not the spot to lift it. you pushed every thing up. there was a spot a little further back. for that. if your car is t low for a cack get acouple pieces of wood and drive the tires on to them for added height..
Old Sep 23, 2004 | 10:09 AM
nayyarn's Avatar
Desi Pride
Good luck....
I think Lawaia, found your problem area.
Old Sep 23, 2004 | 11:57 AM
bigman's Avatar
'Big Daddy Diggler'
first tie the hood to your car, so that while driving to a body shop the hood doesnt fly up. Dont take any highways.
Old Sep 23, 2004 | 12:39 PM
pimpravi's Avatar
I pimp an Audi A4.
well the hood latches... but it doesnt line up flush with my headlights on the right side.. it pops out a little....... its to late to use other methods that u guys said but thanks anyways.. anymore thoughts? im pretty sure what lawaia is saying is correct so il get that checked out.... thanx
Old Sep 23, 2004 | 12:41 PM
bigman's Avatar
'Big Daddy Diggler'
if it closes all the way, but doesnt line up, just take it to a body shop. They can fix that.
Old Sep 23, 2004 | 06:50 PM
fsttyms1's Avatar
open the hood and see if you can see where or if its raised. i know it sounds crude but simply standing on the side thats raised may be enough to get it into place. (most likey a body shop would use simular methods (beating it into place, pushing, or bouncing on it)
Old Sep 24, 2004 | 02:16 AM
gotbeef's Avatar
check the condenser radiator clamps.
they are #8 in the drawing here
those should be flat. if you lifted the car by the condenser radiator you probably bent those things. they sit right next to the hood stops so there's a good chance they are causing your hood to be misaligned.
if they are, you can unscrew them and hammer them out straight. good luck.
i really hope you didn't damage your radiators...
F-C
Motorsports News
33
Aug 22, 2018 09:53 AM
Skirmich
Oct 1, 2015 12:59 PM
Bielikb96
Sep 28, 2015 10:45 AM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
08_UA7_Gr33k
Sep 27, 2015 12:42 PM
