Suggestions before replacing the alternator
Hey everyone, longtime lurker here. I upgraded from my 2000 TL to a fresh '07 about a month ago. Car has been running like a dream but today when I got to work today I was sitting in the parking lot and my battery light came on. Didn't think too much of it but I shut the car off and cranked it up again, and everything seemed fine but the light came on after about a minute. Left work about 2 hours ago and the same light came on, I drove a couple miles down the street and it felt like I was losing power and as I turned at a stop sign my VSA light came on and I couldn't turn it off. I turned into the auto zone on that street and as I turned into the parking spot all the dash lights came on and the car shut off.
I sat in my car for about 30 minutes googling what it could be and everything pointed at the alternator until I started up the car. Left it on for 5 minutes, no battery light, did a few laps around the parking lot with my headlights on to make sure but the battery light never came back on. I drove about 10 miles home, with my hazards and headlights on and it drove like normal. Do alternators come back to life, could it have just had a "hiccup" or is there something else I should check?
A little bit of background info. My car does take a tad longer than my old car to start. The battery was replaced 5/18. I hardwired a dash cam to the cigarette lighter fuse the week I bought the car. There has been a weird belt/creaking noise that my mechanic said was the tensioner pulley.
Bud! google and the search function are your best friend! found this in 10 seconds. https://acurazine.com/forums/3g-tl-p...coming-849823/ and also this! google
Check your battery cables(corrosion, tightness), check your serpentine belt, check your grounds, and prep yourself for some good old fashion reading + trial and error! This forum is amazing for it.
If it turns out to be a bad alternator, might I suggest going on rockauto and getting a denso reman. The remanned denso is the same part number and og one that comes in our vehicles.
Sorry forgot to update. And yes I tried google but for some odd reason I wasn't thinking right and only googled general information about what a battery light entails and symptoms of a failing alternator. Should've been more specific with my research
Ended up being a loose connector. When I was checking to see if the alternator belt was still intact I saw a connector on the alternator was showing a bit of green so I pressed it in. Didn't think much of it because it felt like only the rubber booth moved but I guess the connection was loose.
Should've been more specific but this was at 11PM.
