Suddenly Hating This Car!!!!!
Old Jun 4, 2012 | 07:38 PM
06NH6MTTL's Avatar
Alright so i had a hard to get in third gear condition which i thought i fixed with gm syncromesh. But last week on my way to work i suddenly lost my clutch pedal completely and had to rev match the rest of the way. When arriving at work i opened my hood and saw my hard clutch line rubbing on the end of the shifter assembly which made a pinhole leak. One of the other techs removed the line and bent a completely new line(covered it with rubber hose, new fittings and flared the ends). We bled it and boom we had gears and clutch function, but now i am experiencing a third gear grind when accelerating and shifting to third, fast shifts. I honestly don't think that rev matching for 10-15 mins completely ruined my 3-4 gears syncro.
Any ideas?
Old Jun 4, 2012 | 07:44 PM
Yumcha's Avatar
Yeah...get it into a garage and have it looked at by a mechanic.
Old Jun 4, 2012 | 08:26 PM
06NH6MTTL's Avatar
Lmao i am a mechanic! my question is there a known fix or has this occurred with anyone else or do i need to go to the dealership and beg to have my 3rd gear and clutch master cylinder tsb's performed
Old Jun 5, 2012 | 12:51 AM
gwiffer's Avatar
There's a TSB for the clutch master cylinder?
Old Jun 5, 2012 | 07:23 AM
06NH6MTTL's Avatar
yes let me get it it
Slpr04UA6's Avatar
-------Tim-------
Maybe GM Synchromesh?
Old Jun 5, 2012 | 07:32 AM
06NH6MTTL's Avatar
Courstesy of *********
Acura has recently released a SB for the 04-08 TL 6MT which shows a replacement P/N 46920-S7A-A04 and a failed P/N 46920-S7A-A03.
Service Bulletin 11-004
March 31, 2011
Applies To: 2004–08 TL – ALL with M/T
Clutch Pedal Pops, Squeaks, or Clicks
SYMPTOM
The clutch pedal pops, squeaks, or clicks when you press or release it.
PROBABLE CAUSE
The clutch master cylinder has insufficient clearance between the piston and the push rod.
CORRECTIVE ACTION
Replace the clutch master cylinder.
PARTS INFORMATION
Clutch Master Cylinder Assembly: (Includes clutch master cylinder, O-ring, seal, and snap pin)
P/N 46920-S7A-A04
REQUIRED MATERIALS
Honda Genuine DOT 3 Brake Fluid: P/N 08798-9008 (Each repair requires one bottle.)
WARRANTY CLAIM INFORMATION
The normal warranty applies.
Operation Number: 211101
Flat Rate Time: 1.1 hours
Failed Part: P/N 46920-S7A-A03
Defect Code: 03214
Symptom Code: 04201
Skill Level: Repair Technician
Old Jun 5, 2012 | 08:42 AM
EvilVirus's Avatar
^ Ok if the problem is cause by the clutch master cylinder due to its insufficient clearance; why would replace it with another fix the clearance issue?
Feb 25, 2020 09:57 AM
BreezyTL
Jul 26, 2016 12:52 PM
Phambam12
Sep 6, 2015 06:57 PM
andysinnh
Sep 5, 2015 11:38 PM
jordanboi
Sep 5, 2015 01:33 AM
