Stuck on Park.
Old Nov 30, 2016 | 11:30 PM
Edwin Martinez's Avatar
Stuck on Park.
when i press on the break the light come on and i can override. but could someone help me where the the problem is coming from?? thanks.
Old Dec 1, 2016 | 12:38 AM
srg818's Avatar
You mean you can't shift out of park into gear without using the override? Bad or mis-adjusted brake light switch most likely. Checked your fuses? Does your horn work?
Old Dec 1, 2016 | 02:33 AM
i cant get out of park unless i override. my lights and horn work. ill check fuse once i grt home
Old Dec 1, 2016 | 06:16 AM
usually that means the brake light switch
Old Dec 1, 2016 | 07:54 AM
Evan Myers's Avatar
6th Gear
I am having the same problem. Sometimes it works fine but most the time I have to use override. I will check the switch. Thank you!
Old Dec 26, 2016 | 07:17 PM
Jesse Rivera's Avatar
I have the same issue and I already replaced the brake switch above the brake pedal. Any updates?
