Stripped or broke this bolt
Hi. When I was changing the ATF fluid I removed this plastic cover under the transmission and stripped or broke the bolt in 1/2 and the other 1/2 got stuck. The only I can think of to hold the plastic cover securely is to use a metal coat hanger to tie it down. Any other suggestions
you can drill the broken bolt out.
^^^Typical Justin lol.
justnspace (12-28-2017)
I had the same problem, the two bolts were rusted and the head snapped off clean. Only way is to drill it out.
You might be able to hold it with zip ties.
If it makes you feel any better, I kept mine off the car and it's been over 3 years now and my car sees a lot of salt. No problems for me.
Now I feel like an idiot because I've messed with securing/removing that same cover about 4 different times doing trans fluid drain and refills....I figured it had to be important lol. Looks like i'm tearing that thing off for good next time.
I think it design to catch any small leak instead.
Y'all cover haters are out of your minds.
I'd strongly recommend keeping the cover, OP.
Drill the bolt out or whatever you wanna do. But keep the cover.
They're not useless. They do protect from debris. Not having one makes a HUGE difference if you drive in salt and would like to keep corrosion minimized.
And they keep things from the road like animal guts, human feces, rotted food, blood, urine, raccoon butthole sweat, and mud from getting on your belt and slinging all over the engine which you will at some point, will touch with your hands and/or genitals.
OEM's spend HUGE money on designing the cover. Figures that would make you clutch your chest. Its there for many good reasons.
Keep the cover.
Keep the cover.
Keep the cover.
Keep the cover.
You have convinced me. I will do the tie wrap, quick and dirty! No time to drill and remove the stuck bolt in this 10F cold weather! Should I use the regular plastic tie wraps or metal coat hanger?
Plastic tie wrap should hold better (and not rust). Use a few of them if there's a question of strength. Just make sure you tie them to something solid.
Is it just one bolt that broke? So the cover is drooping a bit or something?
Also, did the bolt break whilst tightening or loosening?
If you broke it when tightening...it should come back out pretty easy. Can you reach the other side of the weld nut? If the bolt stud is sticking through, you can probably just turn it out by hand. A screw extractor bit is another way to quickly remove it. Or...if you use a drill on the broken stud, it will likely jusy spin itself out in 0 seconds.
If it broke on the way out...can you grab the stud with vise grips? Turn it using vise grips.
Or...can you just break the weld nut off and use a regular nut?
All things that seem like a huge task in 10F weather, I know.
It should be a M6x1.0 bolt/screw. Its a JIS style C10.9 flange screw, if were being fancy. McMaster car should carry them for cheap.
Torque is maybe 7LB-FT. So very very light. I anti-sieze all of mine.
Keep the cover.
Keep the cover.
it’s too cold (10 F and windy in Boston) and street parking, it VERY HARD to use drill or vise to remove the snapped bolt underneath the car under this weather conditions. I was able to manage to secure it with a tire wrap and metal coat hanger under 20 minuets. I don’t want it to get caught in the snow plow and bend and dangling and making noises with the ground.
ghost_masterCL
03-11-2006 08:17 PM
