Strange starting issue
Old Jul 12, 2011 | 05:12 PM
MrKinn's Avatar
04 tl 73,000 miles.. ( 1 payment left ) WOOHOOO. Anyways. Started up just fine.. parked car for approx 15 hours. Jumped in cranked it turned over slow then stopped tried it again just clicked waited a second cranked it over. cranked slowly and finally started.. Went home parked it.. Got in it in the morning and it cranked over very slow. im thinking battery.. no problem.. went to advanced they checked battery he said bad battery.. awesome slap a new one in lets roll.. He then checked the alternator and found no issue. however with some more testing he told me something was draining my battery when its completely shut off.. He took my battery out and recharged it and sent me on my way... Later that day i decided to get a second opinion drove to autozone.. tested battery ( which was fully charged 6 hours ago ) comes back dead battery.. so im like screw it. bought a brand new battery.. Today.. ive tried to start it and it cranks over slowly but starts. I have read a few threads about the hfl fuse#6 might becausing the issue. I took the fuse out and ( prior let me car run to charge battery back up ) just tried and its cranking slow again.. Can anyone help me before i get bent over at the dealership??? what is causing my battery to die when everything is completely off???
Old Jul 12, 2011 | 11:00 PM
Tegnut's Avatar
It could be your alternator going bad.
Old Jul 13, 2011 | 10:41 AM
MrKinn's Avatar
i pulled the #6 fuse.. ( which i guess controls ur.. dome light ur hfl and ur keyless entry ) all i have found out so far.. However.. i pulled the fuse and it seemed like it had fixed the issue so far. car started up fine this morning after sitting all night.. Time to read somemore threads to see what is causing it.. Im open for anything
Old Jul 13, 2011 | 11:17 AM
Will Y.'s Avatar
Registered but harmless
It sounds like the HFL went bad per the TSB.
There are several threads on the HFL not disconnecting after the ignition is turned off and related TSB for the '04 TL.
Old Jul 13, 2011 | 03:35 PM
MrKinn's Avatar
so i can put my fuse back in as long as i dont ingauge the bluetooth or set it up ill be fine???
Old Jul 13, 2011 | 04:10 PM
Badfish2's Avatar
Badfish2
If the fuse turns out to be okay it could be your bearings or bushings in your starter motor (depending on the motor itself)
Old Jul 13, 2011 | 05:45 PM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
Chances are it sounds like a faulty cell in the battery. Let the dealership or private shop run a charging system test. This will indicate any issuses with the battery, alternator or if there is a system draw as in the hands free link unit staying on even after the vehicle is turned off.
Old Jul 13, 2011 | 07:35 PM
MrKinn's Avatar
NO.. I bought a brand new battery and it was dead by the emd of the day.. The alternator was checked at 2 places and it was pushing 14. plus amps so that was fine.. Yesterday i removed fuse #6 and so far no drainage
Old Jul 13, 2011 | 09:46 PM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
Disconnect the hands free unit yourself it's very easy.
Old Jul 14, 2011 | 03:31 PM
MrKinn's Avatar
due tell please
cycdaniel
Dec 17, 2019 10:58 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
SilverJ
1/2G MDX (2001-2013)
Sep 21, 2015 02:40 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
NSolace
Sep 3, 2015 08:14 PM
