Strange noise after changing tire
Old Jun 1, 2012 | 12:14 AM
bonnhew's Avatar
so i had my passenger side front tire changed two days ago and ever since that i hear a strange grinding/vibrating noise when the car comes to a stop. the tire size is exactly the same as manufacture recommended (stock TL-S wheels) does anybody know whats going on?
Old Jun 1, 2012 | 12:27 AM
pohljm's Avatar
Why did you need to change out a single tire?
Old Jun 1, 2012 | 12:47 AM
bonnhew's Avatar
i actually had to change two. old ones were pretty worn out and woudnt pass the inspection. but the noise is coming only from the front passenger side.
Old Jun 1, 2012 | 11:44 PM
LaCostaRacer's Avatar
I trust your brake pads are good? I would try torquing the lug nuts but that's a long shot. My money is on the pads and the wear indicators doing their job.
Old Jun 2, 2012 | 03:28 AM
bonnhew's Avatar
i just changed all brake pads a lil while back. so im pretty sure they are good. I never had this noise before i got the tires changed.
Old Jun 2, 2012 | 08:11 AM
usmarinedelta's Avatar
Make sure you heatshield is not bent, not even a little.
Old Jun 2, 2012 | 08:53 AM
fabricator's Avatar
Are you running factory wheels/tires? Check the wheel weight location. They might be making contact with the caliper, some tire shops do not pay attention to placement. i see it alot.
Old Jun 2, 2012 | 10:34 AM
Jesstzn's Avatar
Pull that wheel and look it over. And like said above check the shield when you have it off. You could even stick the spare on for a short trip to see if it went away.
Feb 25, 2020 09:57 AM
2012wagon
Sep 29, 2015 04:21 PM
devinv1994
Sep 8, 2015 01:29 PM
aces2412
3G MDX (2014-2020)
Sep 7, 2015 08:40 PM
emsrph
Aug 31, 2015 10:28 AM
